Thread started 23 Jul 2009 (Thursday) 02:33
Mixed batteries in grip
javig999
Jul 23, 2009 02:33 |  #1
Is it ok to combine battery brands in a battery grip? For example a OEM Canon battery with a Opteka 3rd party battery without issues down the line?
Thanks in advance...
7D | 8mm 3.5 FE | EF-S 10-22 | EF-S 17-55 2.8 IS | EX DC 30 1.4
EOS R | Samyang 14 2.8 | Sigma 15mm f2.8 DFE | RF 16mm | Art 20/35/50/85 f1.4 | EF 100 f2.8 Macro | EF 135 f2L | EF 70-200 f2.8L IS | Sigma C 150-600
duntov
Jul 23, 2009 02:49 |  #2
I mixed batteries in my Rebel XT without any problems. Otherwise you could just use one battery at a time in the grip and use the other one as a reserve.
Canon 7D,Canon 5D, Canon 40D, Canon Rebel XT, Canon 85 1.8, Canon 50 1.4 Canon 100-400 mm L, Canon 70-200 F4 L, Canon 17-40 F4 L, Canon 24-70 F2.8, Canon 100 Macro 2.8, Speedlite 430EX (X 2), Elinchrom D-Lite 4 set to go
jluspo
Jul 23, 2009 08:42 |  #3
javig999 wrote in post #8328787 (external link)
I have Canon battery and Opteka battery in my grip - no problem.
Gear List: Canon EOS 7D; Sigma 10-20; Canon 50 1.4; 24-105 F4L; 100-400 F4.5-5.6L IS; 580EX II; 2x Calumet Genesis 200; Billingham/Think Tank/Tamrac bags
Jon ­ Foster
is it safe?
Jul 23, 2009 08:52 |  #4
We mix Canon and no name batteries in our grips all the time. It's been about 5 years without any problems...
Jon.
I shoot with a Little Canon
Check out my photos @ PBase.com (external link) & ModelMayhem.com (external link)
javig999
Jul 23, 2009 09:18 as a reply to  @ Jon Foster's post |  #5
Thanks all....ordered the Opteka and this should provide plenty of back up power as well as some added balance once in the grip...
JWright
Joined Dec 2004
Jul 23, 2009 18:57 as a reply to  @ javig999's post |  #6
I have the original Canon battery and a Delkin e-film battery in my 40D and haven't had problems. All I did was make sure they were fairly close in their mAh ratings... The Canon is 1390mAh and the Delkin 1400mAh.
John
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jul 23, 2009 22:03 as a reply to  @ JWright's post |  #7
Presuming the batteries are compatible with the camera in the first place, it's no problem.
All the Canon consumer grips are designed to draw from the stronger battery first until it's equal to the weaker, then it alternates a few shots at a time between the two batteries to draw them down at the same rate.
So it doesn't matter if one battery is of greater MaH than the other. Even if one battery were totally drained, the grip would just draw from the fresh one.
1,072 views & 0 likes for this thread, 6 members have posted to it.
974 guests, 108 members online
