Thread started 23 Jul 2009 (Thursday) 10:03
Out Of Scratch Memory
W.E.S.P
"Terror Byte"
Jul 23, 2009 10:03 |  #1
Ya lo all,
Im having a few problems saving for web, getting the out of scratch memory error message. I have allocated the scratch memory to my internal HD which has 200GB (ERROR MESSAGE) I'm also using my external HD which is 1 terror bite and im still getting the error message. I have got 2GB of memory as well.
Is there anything else i need to try cos this shouldnt be happening
canon 40D / canon 17-85mm IS USM / sigma 105mm Macro / Sigma 70-300mm APO DG
Redfish
Jul 23, 2009 10:14 |  #2
When allocating SCRATCH memory in the photoshop preferences tab, select all internal drives available. It picks the most available location - You may run into problems if you select an external drive - or certainly be slowed down. Been there, done that, followed Adobe's advice (as presented here) and things are working great - also allocated RAM should be about 75% - good luck
Canon 1DXIII (2) Eos R 5R on the way 15-600 /1.2 - 5.6
6000ex's Bee's and boxes & PW's
RRS tripods and heads
W.E.S.P
"Terror Byte"
Jul 23, 2009 10:29 |  #3
Redfish wrote in post #8330288 (external link)
Tried it pal, not working
René ­ Damkot
Jul 23, 2009 11:32 |  #4
How big is the image you're trying to save?
Try this: Flatten, convert to 8bpc, reduce size, then SFW.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Lowner
"I'm the original idiot"
Jul 23, 2009 12:29 as a reply to  @ René Damkot's post |  #5
I've allocated the scratch disc to my external hard drive and experienced no problems at all. Even when I've forgotten to turn it on, which I often do, Photoshop just finds somewhere else.
My previous PC used to constantly give me those errors, and its one reason I never store images on the PC's hard drive, only on the external HD which is bigger anyway.
Richard
wyofizz
Jul 23, 2009 13:37 as a reply to  @ Lowner's post |  #6
Have you tried clearing/purging the cache in Preferences?
Dave - Fuzzy Hashing makes me itch.
W.E.S.P
"Terror Byte"
Jul 23, 2009 19:50 |  #7
wyofizz wrote in post #8331320 (external link)
don't know why i didn't think of doing that, but its fine now.
sapearl
Gallery: 243 photos
Jul 24, 2009 05:42 |  #8
Glad to hear it worked out for you - easy to overlook that feature..... after all these are complex programs and we often get caught up in the trees instead of the forest. You don't always know what you don't know. :D - Stu
W.E.S.P wrote in post #8333121 (external link)
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
Dave ­ R.
Jul 24, 2009 06:05 |  #9
Sorry, but can someone tell me the steps to do this? Sounds like something that should be done even if you aren't having trouble.
W.E.S.P
"Terror Byte"
Jul 24, 2009 07:28 |  #10
Dave R. wrote in post #8335053 (external link)
Open bridge, tools, cache, purge cache, Jobs a gud n. ;)
René ­ Damkot
Jul 24, 2009 07:28 |  #11
Photoshops cache is emptied every time you close PS. No need to unless you run into a problem like this. (Which should be unlikely, unless you have little memory & little free disk space.)
W.E.S.P wrote in post #8335261 (external link)
That's a different cache: The one for Bridge.
Also worth noticing that the one in the bridge prefs appears to be broken (doesn't rebuilt thumbnails):
HTTP response: 403 | MIME changed to 'application/xml'
The PS cache is here:
IMAGE: http://img.skitch.com/20090724-deub1skfucjk91d3pn75j3f9yk.jpg
W.E.S.P
"Terror Byte"
Jul 24, 2009 07:39 |  #12
René Damkot wrote in post #8335262 (external link)
I was trying to do it through photoshop but it wouldn't work. It worked straight away when i cleared the cache in Bridge. Clearing it in Bridge did the trick for me. Im not saying this is the correct way to do it, but it got running better.
1,500 views & 0 likes for this thread, 7 members have posted to it.
1105 guests, 174 members online
