Thread started 23 Jul 2009 (Thursday) 18:59
Opening a can of worms - my first flash question to you guys.
pixel_junkie
Jul 23, 2009 18:59 |  #1
Hi guys!
While I have a pretty good idea about using a camera overall, flash photography is very new to me. So far, I’ve relied on fast lenses for all my low light images. However at times like shooting on the beach facing the sun and having a subject facing the camera as well, I’ve realized that a shot like that just can’t happen without a flash to put some light in the subject’s face.
I’ve been reading a lot about using flash. I don’t feel like I’ve learned that much yet but I’m plugging along. So I wanted to use the answers of the following question as more or less first stepping stone on my way to concur flash photography.
Here’s the scenario – just like the example above, if I was to shoot a subject on the beach – me facing the sunset, her standing against the sunset and facing the camera such as the example bellow – if I’m shooting in AV the way I have been (I’m comfortable with that mode), how would I control the power of the flash?
Obviously I want to put just a little bit of light into the subjects face, just enough so she isn’t a silhouette at the end. The sunset is the main event on the picture.
Do I set the camera as I would if I was shooting without flash and then dial in manually just enough power on the flash until I’m happy with the results?
Is it a wrong approach to set up the camera first and figure out the flash exposure later by testing different power settings?
I guess the main thing I need to understand is the sequence of setting up both camera and flash and also I imagine leaving the camera to control the flash won’t do the trick so what is the best/quickest/standard way to control the flash output – all this in aperture priority mode?
Any replies to this would be greatly appreciated!!!
Website (external link) | Blog (external link)
DDCSD
GIVIN' GOOD KARMA
Jul 23, 2009 19:03 |  #2
First of all, do not use your flash in AV mode. AV mode is usually terrible with flash unless you really know what you're doing (and if you really know what you're doing, use M) or are using the flash only as fill. Use M when using flash in a situation like you posted above. The only time you'd want to be in AV is if you're only using the flash for fill light, which is not the case in the above photo.
Set up your camera to get the exposure that you want on the background, then adjust your flash/strobe's power to get the exposure that you want on the subject that you are illuminating with the flash.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
pixel_junkie
Jul 23, 2009 19:10 |  #3
DDCSD wrote in post #8332905 (external link)
Thanks Derek! How come? What does AV do to the flash that M doesn't?
You just fire a test shot and then adjust the EFC on the actual flash separate from the camera?
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Jul 23, 2009 19:11 |  #4
There is a great deal on this method at
http://www.strobist.co​m (external link)
It is a common approach to set the camera for the background, possibly 1-2 stops down from "normal", and then set the flash to light the subject.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
DDCSD
GIVIN' GOOD KARMA
Jul 23, 2009 19:18 |  #5
pixel_junkie wrote in post #8332946 (external link)
AV mode will attempt to expose the ambient light. It will likely give you way to long of a shutter speed, or way too short. The shutter speed will also vary wildly depending on exactly where you point the camera.
In that situation, I would put the flash on M as well. You're in a controlled situation with a very difficult scene for the camera to meter. If the model move a hair in any direction, your camera/flash could choose wildly different settings.
Derek
pixel_junkie
Jul 23, 2009 19:19 |  #6
CliveyBoy wrote in post #8332960 (external link)
Thanks! I'll eat that site for dinner tonight!
pixel_junkie
Jul 23, 2009 19:25 |  #7
DDCSD wrote in post #8332993 (external link)
Sounds like I've chosen an extra difficult scene as an example. What if you're in a more controlled environment? Would shooting in manual and adjusting the FEC as a secondary step not be appropriate? I'm trying to figure out not so much how to do that shot but more what the basics are when setting up any shot. Step A - set up camera in manual for proper exposure, ... step B?
pixel_junkie
Jul 23, 2009 19:27 as a reply to  @ pixel_junkie's post |  #8
One more thing - if I'm in AV, there's no way to override the Flash and control its output entirely?
drh681
Jul 23, 2009 19:38 as a reply to  @ pixel_junkie's post |  #9
the trick with AV mode and flash is to set the custom function for shutter speed with flash to maintain 1/250 of a second.
but manual is almost a necessity for a scene such as your example.
and yes Flash Exposure Lock (FEL) is very effective for that sort of scene also.
as you surmise, it separates the flash exposure calculation from the overall scene exposure calculation.
theveed
Jul 23, 2009 19:48 |  #10
pixel_junkie wrote in post #8333029 (external link)
You could, just switch your flash to Manual...
bobbyz
Jul 23, 2009 19:52 |  #11
Like others mentioned keep camera in manual exposure mode. FLash can be in eTTL.
You select aperture based on dof you need. Select ss and ISO for bg ambient light. Then just use FEC for proper subject exposure.
If you need to darken bg, increase ss. If need to bring up bg, slower ss. At sunset you won't be limited by flash sync speed of the camera.
Fuji XT-1, 18-55mm
pixel_junkie
Jul 23, 2009 20:12 |  #12
theveed wrote in post #8333114 (external link)
That's what I though. So if this is possible and I already know how to set up the exposure in AV well, what would I gain by using manual on the camera? If I need to underexpose the shot in AV (or overexpose, .. whatever), I can do that and then go to my flash end adjust IT to light up my subject as much as I want (by doing it manually). Would I be doing more work than necessary?
Sorry guys, not trying to be difficult, just trying to understand the advantage of Manual mode for the camera and its relation to the flash.
msowsun
"approx 8mm"
Gallery: 18 photos
Jul 23, 2009 20:25 |  #13
Av mode or Manual mode are used ONLY for the ambient light exposure.(background) In this case you need to underexpose the ambient light. This can be done with a -EV exposure compensation using Av or Manual mode.
The flash will be the main light for the subject. This can be ETTL or manual flash.
Some test shots and trail and error will be necessary.
TMR ­ Design
Joined Feb 2006
Jul 23, 2009 20:46 as a reply to  @ msowsun's post |  #14
Once you're using flash or strobes the idea is to NOT have the camera do the thinking for you, as it doesn't always make the right 'suggestion'. When you shoot in manual mode you're taking control of every aspect of the shot and the exposure. You're using shutter speed to accurately control the amount of ambient light in the shot and you're using aperture to control both depth of field and the amount of flash in your shot.
Any of the auto modes will not always give you the results you want and won't give you consistent results. Repeatability is the key to controlling light.
Robert
pixel_junkie
Jul 23, 2009 21:55 |  #15
msowsun wrote in post #8333255 (external link)
Thank you sir!
TMR Design wrote in post #8333341 (external link)
Okay, thanks. Got it. So when you shoot with flash, do you set up both manually always or only your camera stays in manual?
3,593 views & 0 likes for this thread, 12 members have posted to it.
1125 guests, 112 members online
