Thread started 25 Jul 2009 (Saturday) 02:12
Lee Foundation Holder issue
WillOPhotos
Jul 25, 2009 02:12 |  #1
Just want to warn people, not sure if this has been mentioned on here before, But my Lee Holder came apart after 3 days of use so I thought it might help, The little spring loaded pin that you pull to clip the holder onto the ring with is a threaded screw and in my case didn't have loctite or anything on it and came apart while shooting a waterfall and I lost one of the parts :mad: luckily the store was good and swapped it.
Will.
Hassy H4D-40, Gitzo 3541XLS, RRS BH-55
http://www.flickr.com/​photos/willophotograph​y/ (external link)www.williamophuis.com/​blog << add blog for some reason it goes to my main site :) (external link)
argyle
Jul 25, 2009 06:47 |  #2
You should make a habit of checking your equipment before and after each use. I've been using a Lee holder for several years and have never had any problems with it...then again, I always give my gear a once over before using.
Something else you need to be careful/aware of: the spring in the brass clip has a fairly low spring constant, which makes the spring force a bit "soft". If you happen to be handholding the camera with the holder installed, and the holder should "catch" on something, it will separate from the adapter ring (rather than being held firmly and the "catching" force being translated to the lens mount)...this will protect the camera/lens, albeit at the cost of a possible lost holder and filter. So if you happen to be resting the camera/holder on a railing or something similar for support, be mindful once you've taken the shot and lift your camera.
WillOPhotos
Jul 25, 2009 07:03 as a reply to  @ argyle's post |  #3
Yeah your right I check all my gear before use also :) I purchased this holder the day before I left on a 4 day photo trip of non stop Photographing so I expected "the best" Filter holder out there to not fall apart after 3 days of use haha A metal on metal thread should have some kind of Loctite or something in my opinion, dont get me wrong it is an awesome holder and used with the AW rings its a pleasure to use with the 16-35mm on FF.
MDJAK
Jul 25, 2009 07:13 |  #4
check gear? What's that? The only thing I check is my coat, and only if the coat check girl is hot. ;)
me
argyle
Jul 25, 2009 07:24 |  #5
MDJAK wrote in post #8340490 (external link)
me
But that all depends on your definition of "hot"...:D
MDJAK
Jul 26, 2009 17:35 |  #6
argyle wrote in post #8340520 (external link)
Oh, trust me, my definition of hot would have you drooling. Let's not forget, I live in NYC home of the most beautiful women per square foot. :)
me
argyle
Jul 26, 2009 18:05 |  #7
MDJAK wrote in post #8347316 (external link)
me
I was born and raised in the NY/NJ area, but overall I think Texas women have them beat by a country mile or two. After living here now for so many years, I'll take a good looker with a southern accent over that New Yawk accent anytime (but it sounds like you're definition of hot may be similar to mine anyway). ;):D:D
2,245 views & 0 likes for this thread, 3 members have posted to it.
1466 guests, 173 members online
