Just a question which came up recently and I am wondering if bad glass can cause extra noise?
Jul 25, 2009 03:18 | #1 Just a question which came up recently and I am wondering if bad glass can cause extra noise? http://natureimmortal.blogspot.com
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Jul 25, 2009 03:24 | #2 No. people will always try to stop you doing the right thing if it is unconventional
Jul 25, 2009 03:35 | #3 Neilyb wrote in post #8340064 I am wondering if bad glass can cause extra noise? Only if you drop it. Dusty
wickerprints "Shooting blanks" 864 posts Joined Jul 2009 More info | Jul 25, 2009 03:37 | #4 A poor-quality lens can be extremely soft, show distortion, or have poor contrast. It is the last shortcoming that can make sensor noise appear worse, although the noise is intrinsic to the sensor. So my answer to your question is..."sort of." It's not going to cause extra noise, but it could make existing noise appear worse as the signal (the actual image) is not as strong due to light losses/artifacts as the image passes through the lens. 5DmkII :: EF 24-105/4L IS :: EF 85/1.8 :: EF 70-200/2.8L IS :: EF 100/2.8L IS macro (coming soon!)
Jul 25, 2009 03:38 | #5 A valid point was made about signal-to-noise ratio, the sensor depends on the light but the lens affects the light entering the camera...but I would argue an f5.6 lens should allow the same amount of light whatever the grade of lens? Cant imagine a lens being so bad that the light would be bad.... http://natureimmortal.blogspot.com
neil_r Cream of the Proverbial Crop Landscape and Cityscape Photographer 2006 18,065 posts Likes: 10 Joined Jan 2003 Location: The middle of the UK More info | Jul 25, 2009 03:41 | #6 no but poor exposure can Neil - © NHR Photography
wickerprints "Shooting blanks" 864 posts Joined Jul 2009 More info | Jul 25, 2009 03:56 | #7 Neilyb wrote in post #8340096 A valid point was made about signal-to-noise ratio, the sensor depends on the light but the lens affects the light entering the camera...but I would argue an f5.6 lens should allow the same amount of light whatever the grade of lens? Cant imagine a lens being so bad that the light would be bad.... ![]() I see the point about contrast, I guess after PP it would become worse - but then the same would go for sharpening. You're confusing aperture with MTF. While MTF is affected by f-number, it is not merely the amount of light falling on the sensor that determines the quality of the signal. 5DmkII :: EF 24-105/4L IS :: EF 85/1.8 :: EF 70-200/2.8L IS :: EF 100/2.8L IS macro (coming soon!)
wickerprints "Shooting blanks" 864 posts Joined Jul 2009 More info | Jul 25, 2009 04:00 | #8 Perhaps a simpler way to think about it would be to look at a noisy image that contains areas of low detail and high detail. The low detail areas, like out-of-focus bokeh, will show noise patterns more clearly than areas where detail is high, because the high detail "overpowers" the perceived noise, even though in actuality it is more or less constant throughout the image. 5DmkII :: EF 24-105/4L IS :: EF 85/1.8 :: EF 70-200/2.8L IS :: EF 100/2.8L IS macro (coming soon!)
Jul 25, 2009 04:04 | #9 wickerprints wrote in post #8340156 Perhaps a simpler way to think about it would be to look at a noisy image that contains areas of low detail and high detail. The low detail areas, like out-of-focus bokeh, will show noise patterns more clearly than areas where detail is high, because the high detail "overpowers" the perceived noise, even though in actuality it is more or less constant throughout the image. Thus if a lens cannot register high detail, more of the underlying sensor noise becomes evident. Which was what I was trying to figure out, would it be severe enough to make a difference? Thankyou for your explanation. http://natureimmortal.blogspot.com
JeffreyG "my bits and pieces are all hard" More info | Jul 25, 2009 06:46 | #10 Neilyb wrote in post #8340064 Just a question which came up recently and I am wondering if bad glass can cause extra noise? Just one point to clarify, there are actually some older Canon lenses that will generate 'noise' in an image. I think a search on the topic will find the list. These film era EOS lens' processors / AF motors generate electromagnetic noise that shows up on digital EOS cameras. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jul 25, 2009 07:30 | #11 wickerprints wrote in post #8340140 You're confusing aperture with MTF. While MTF is affected by f-number, it is not merely the amount of light falling on the sensor that determines the quality of the signal. Please define what MTF means. I could not find the meaning of the acronym. Skip Douglas
TeamSpeed 01010100 01010011 More info | Jul 25, 2009 08:11 | #12 ^ (modulation transfer function) but that probably helps about as much as the acronym.... Past Equipment | My Personal Gallery
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jul 25, 2009 09:28 | #13 TeamSpeed wrote in post #8340617 ^ (modulation transfer function) but that probably helps about as much as the acronym.... http://www.normankoren.com/Tutorials/MTF.html Thanks for the link. Skip Douglas
| Latest registered member is semonsters 1457 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
