Thread started 25 Jul 2009 (Saturday) 09:12
50D need advice
albasit
Jul 25, 2009 09:12 |  #1
Hi All,
I'm new here..I just upgrade my 450D to 50D. Feel nice with the grip.
The LCD is wow, but when I transfered the image to the notebook, the result is not clear and bright as in the LCD. Is that normal or something wrong with my 50D ?
I'm using 17-55, and 50 1.8, back then using 450D the image was just the same between LCD and notebook, even when I used PS Standard. Now, my pic in notebook feel very neutral. I already did some customize with PS, but still I'm not satisfied with result.
Please advice..
Thanks.
5D 50 135 24-70
pantherphotos
Jul 25, 2009 09:23 |  #2
Are you shooting RAW or jpeg? If I'm not mistaken, if shooting RAW, when you view the image on your lcd, any picture style that is selected in your menu will be applied; but when uploaded to your computer, it will be without any adjustments. You have to make all adjustments yourself. You always have to apply a little sharpening and color saturation.
Another possibility is that notebook screens cannot be calibrated (as far as I know; if I'm wrong please let me know b/c I would love to calibrate mine). So colors may be off and look a little flat.
Eric
Canon EOS 1D MkIIn | Tamron 28-75 f/2.8 | 70 - 200 f/2.8L | 50 f/1.8 II | 2x YN560 flash
My Blog: http://pantherphotogra​phy.wordpress.com/ (external link)FACEBOOK (external link)
MikeFairbanks
Jul 25, 2009 09:34 |  #3
Keep in mind that even a blurry image will look pretty sharp on a three-inch screen. Are you zooming in when viewing on the LCD to look at detail?
Thank you. bw!
albasit
Jul 25, 2009 09:37 as a reply to  @ pantherphotos's post |  #4
Hi pantherphotos,
thanks for the response.
I'm using both...hm..I think PS also applied with transfered image.
Also I'm seeing other 50D photos are not flat with this notebook..
5D 50 135 24-70
albasit
Jul 25, 2009 10:03 |  #5
HI Mike,
Yes, I agree with the blurry thing, but I do zoom at LCD and the sharp is fine. Only the color is different between LCD and notebook, it's flat..
5D 50 135 24-70
Westx
Gallery: 6 photos
Jul 25, 2009 10:15 as a reply to  @ albasit's post |  #6
Make sure both notebook and camera are set to sRGB. If flat one may be set to aRGB.
albasit
Jul 25, 2009 10:49 |  #7
I tried change it to sRGB and aRGB..still flat..
I also adjust my laptop monitor, but the image become darks..
Is my 50D has colour problem ?
5D 50 135 24-70
Guts311
Jul 25, 2009 12:23 |  #8
No problem I don't think..the 50D's LCD screen is just VERY very colorful and sharp due to how many pixels are crammed into that size. No matter what, the pic will look good there. Same thing on mine compared to the real photo on the PC.
I don't think anything's wrong. But I do agree that seeing it on the LCD is little deceiving because it almost always looks better than the real thing does...
Methodical
Gallery: 239 photos
Jul 25, 2009 16:12 |  #9
Guts311 wrote in post #8341557 (external link)
... I don't think anything's wrong. But I do agree that seeing it on the LCD is little deceiving because it almost always looks better than the real thing does...
I had the same issues when I first got my 50D but after awhile I got pretty good at identifying a good image or a so so image when viewing them on the 50D screen. It's just the opposite on my MkIII screen...sometimes I think the image is bad until I upload to the computer and it would look better than on the camera's screen. The 50D screen is way better than the MkIII screen.
Gear
MethodicalImages (external link)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
vincent_su
Jul 25, 2009 18:37 as a reply to  @ Methodical's post |  #10
The standard LCD brightness setting is very bright. I open the same picture in my camera and compare the brightness to what I see on screen. Then, I adjust the LCD brightness to 3 and it's close to my screen now. My screen is calibrated btw.
If you check the histogram and they looked ok, you should be fine. Three questions:
1) what screen of your computer?
2) is it calibrated?
3) can you post a picture that you think it's flat?
Vincent
"My dark room is bright and I like it."
5Diii; 24-105 f/4; 100 Macro f/2.8; 17-40 f/4; 70-200 f/4 IS; 100-400 II; TS-E90 and stuff.
itzcryptic
Jul 25, 2009 22:09 |  #11
We can't really tell if there is anything wrong with the pictures unless we see them, otherwise, it's a shot in the dark.
albasit
Jul 25, 2009 22:44 as a reply to  @ vincent_su's post |  #12
the pic histogram that I shoot won't reach the right (bright) side, I also tried user def PS still no luck with that.
it's notebook XGA Matte LCD Screen
I can set the brightness, tried that still flat. With 450D I didn't need to calibrate the LCD to get the exact colours..
the pooh colour should be yellow, but it's look pale at that pic, the box white also looks little bit grey to me..the bed sheet also little bit pale
I shoot with Portrait PS, RAW, and then converted it to JPEG with DPP, and resize with PS3. No adjustment.
The problem is..I couldn't tell the image I take will be good or not until I transfer to the notebook. The image in 50D LCD is so great, bright and clear.
With my 450D (already sold that.. :( ) I can tell whether the image good enough or not in the LCD. Should I go to the Canon service for checking ?
5D 50 135 24-70
C.Champion
Jul 25, 2009 23:51 |  #13
What is sRGB and a RGB? thanks CC
Westx wrote in post #8341047 (external link)
Hand_of_Cod
Jul 26, 2009 03:36 |  #14
albasit wrote in post #8343788 (external link)
I think shooting in Portrait Picture Style is the problem. Try shooting in Standard or Neutral.
https://andrewferris.s​mugmug.com/ (external link)
vincent_su
Jul 26, 2009 22:50 as a reply to  @ Hand_of_Cod's post |  #15
To OP: questiosn--
1) What lighting setup you have for the shot? I saw the shutter speed is 0.8 sec.
2) Also, what white balance you used for this, I could not find it at all.
3) This picture does not looked flat to me. Can you be more specific what you meant by flat?
Here are some of my humble opinions.
From your picture, I don't see anything wrong with your equipment, so far. The color is off from your screen may not be off because
1) your screen is not calibrated
2) what lighting you use for the shot will affect the color
3) if you applied proper WB
As for pushing histogram to the right, I really don't think is correct for this picture. The majority of this picture's pixels are above mid tone and I don't see a lot of WHITE subject in your picture, why do you think you need them to be at high tone?
Also, try another shot with AV mode and set the style to Neutral. Make sure to provide lighting and WB info and we will go from there.
Vincent
2,045 views & 0 likes for this thread, 11 members have posted to it.
50D need advice
1578 guests, 195 members online
