OK, if you mask all masks black, only the bottom layer shows up untilyou "reveal" something from an upper layer by painting white into the mask.
Try starting this way to simplify things: after all upper layers have a black-filled mask, first turn off visibility of all but the background and lower layer so you won't get confused, then click on the mask of the layer on top of the background (the only other visible one). A little white rectangle should surround the black mask. Now, look over at your color picker toward the bottom of the toolbar -- it should show black as the foreground color and white as the background -- if not, click "D" to set the default colors and it will be done.
You will see that the image appearing is the bottom blackground layer.
Now, click "X" to switch the background and foreground colors -- you will see the foreground white, the background black.
Now, click the Eye icon for the active layer on and off to ensure where the kid is, then select the Brush tool ("B") and paint white over that area and you should see the kid appear (you will see a little white appear on the black mask, Even though you are painting a boy into the image).
That's some beginning ideas. Check out this thread, I think you'll find some very similar aproaches:
https://photography-on-the.net/forum/showthread.php?t=684724
