Hi guys...
I'm planning to go to Ireland in a month or so and want to pack fairly light, but also not chance missing a shot. I'm taking my 5D mkII.
A few questions -
1) I have a 24-70 2.8 L right now. I think it would help to be able to go a bit wider, so I'm planning to rent or buy the 17-40 L (was considering the 16-35, but it uses different size filters than what I have (77mm) so I can't really). Do you think it's worth it to bring both the 17- 40 and the 24-70?
2) I want to get an L plate (probably from RRS) for my camera but I'm not sure if I should get the one for the camera with the grip, or without. I'm thinking of not taking my grip with me, just to save a bit of weight, which means I should get the corresponding L bracket. But... when I'm not traveling I have the grip on all the time, which means I'd have to start taking it off whenever I want to use the L plate... So should I just get the L plate for the body with grip, and suck it up and take the grip with me on my trip?
3) I have a 70-200 2.8 L and an 85 1.2 L. Both heavy... I'm not planning to take the 70-200 due to weight and doubt I'd use it much. But the 85 L might be good for shots in the pubs and when it's darker, especially if I take only a 17-40 which is only F4... What do you think, is it worth it to bring it?
Any other suggestions? I'm up for renting or borrowing just about anything for this...
Thanks!
