Hi I have a canon powershot G6, and when i turn it on the view screen start up photo and then starts to turn white. can any one help me and tell the problem.
Dai.
daijones Hatchling 3 posts Joined Jul 2009 More info | Jul 27, 2009 09:07 | #1 Hi I have a canon powershot G6, and when i turn it on the view screen start up photo and then starts to turn white. can any one help me and tell the problem.
lefturn99 Senior Member 820 posts Joined Feb 2005 Location: Tulsa Oklahoma USA More info | Jul 27, 2009 11:41 | #2 What shooting mode do you have it on? If it's on M, that could be the problem. Otherwise, bad news. 6D, 5D Mk III, 60D, EOS M, Gear List
lefturn99, thanks for reply, just turned the camera on and used it and all seams fine now:o. but as i said if i turned it on the view screen would fade away and turn white, and had the camera in p mode. and it has done this in the past and then worked ok after that.
lefturn99 Senior Member 820 posts Joined Feb 2005 Location: Tulsa Oklahoma USA More info | Wonder if you had exposure compensation cranked up. Next time put your hand over the lens and see if it turns dark. If it doesn't, she's dying a slow death. I learned a lot from my G6, but you would be amazed how much newer cameras have improved. 6D, 5D Mk III, 60D, EOS M, Gear List
| Latest registered member is Thunderstream 1144 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
