Thread started 27 Jul 2009 (Monday) 11:36
problems with merging layers
magal
Jul 27, 2009 11:36 |  #1
When I get to merge the various adjustment layers [In PS] , I use flatten image. I tried merge visible but was surprised by the transformation that takes place; over saturation and high contrast with a rather inaccurate [colours and hue] overblown image. What baffles me is that this does not happen regularly but [It seems] at the program's whims.
Has anyone ever encountered this situation with PS CS4?
Cheers
Mark
Mark
http://www.magal.webs.​com/ (external link)
Lowner
"I'm the original idiot"
Jul 27, 2009 11:56 |  #2
magal,
I use PS7 not CS4, but I don't recognise the problem and I assume the two versions are similar.
Richard
René ­ Damkot
Jul 27, 2009 13:14 |  #3
Happens when one of the layers is not in "Normal" blend mode, or is clipped to a layer IIRC.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Bobster
Jul 27, 2009 19:20 |  #4
try this - ctrl (cmd), alt (option), shift + e
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
Gear | Gram (external link) | Ultimate Lens MA FoCal 2 (external link)| Ultimate RAW Editor C1 (external link)
magal
Jul 29, 2009 03:12 |  #5
Thanks to all the replies....one querie on
Bobster wrote in post #8353556 (external link)
Do you mean I do this when I have to merge the layers instead of using the layers tab?
Cheers
Mark
Mark
Bobster
Jul 29, 2009 11:49 |  #6
instead of ctrl+e to merge layers or going through the layers tab..
it merges all visible layers and creates a new layer from them (nothing is flattend)
René ­ Damkot
Jul 29, 2009 12:08 |  #7
Make sure you are on the top layer when using Stamp Visible ;)
magal
Jul 29, 2009 13:59 |  #8
René Damkot wrote in post #8363372 (external link)
top layer = background layer?
The last layer I create is a background layer copy and on this I apply a low pass filter and noise reduction [when necessary]. Then I apply merge visible through the layers tab [whilst still on this layer]. Do you think this is what I'm doing wrong?
Mark
René ­ Damkot
Jul 29, 2009 14:04 |  #9
Post a screenshot of your layers palette.
What I meant was that you must be at the top of the layer stack, since if you do Cmd+Shift+Opt+e (Stamp Visible) the result will be one above where you are. So if you do a Stamp Visible while on your background layer (the lowest), then the Stamp visible will be just one above that. If you have for instance a bunch of curves / hue/sat / whatever adjustment layers on to, they will then be applied twice after the "stamping" is done....
Let me see if I can create an example...
René ­ Damkot
Jul 29, 2009 14:14 |  #10
Here;
The basis: image with curves adjustment layer:
IMAGE: http://img.skitch.com/20090729-njy4kqx7kwd32sgmiacc19b144.jpg
After "Stamp Visible" while on the adjustment layer (as in: Right after the last screenshot):
IMAGE: http://img.skitch.com/20090729-1eyutscns996uymt89qkm9j7nx.jpg
Step back in time to first screenshot. Note I'm now on the background layer:
IMAGE: http://img.skitch.com/20090729-84hhj6awktex66hb7qeuskyyir.jpg
If I do "Stamp Visible" now, this is what happens:
IMAGE: http://img.skitch.com/20090729-8yb6kwce82fyid7wukmpuapsfd.jpg
That's why I said to "make sure you are on the top layer".
This does *not* happen with "Merge Visible" (Cmd+shift+e). I was merely adding to Bobsters post ;)
magal
Jul 30, 2009 02:58 |  #11
René Damkot wrote in post #8364082 (external link)
What I meant was that you must be at the top of the layer stack, since if you do Cmd+****+Opt+e (Stamp Visible) the result will be one above where you are. So if you do a Stamp Visible while on your background layer (the lowest), then the Stamp visible will be just one above that. If you have for instance a bunch of curves / hue/sat / whatever adjustment layers on to, they will then be applied twice after the "stamping" is done....
Thanks for the super detailed explanation. I see what you mean and what I was actually doing. After finishing with usual curves, vibrance...etc etc, I create another layer for sharpening [Using low pass filter]. I do this by dragging the bg layer icon onto the create new layer icon and this effectively puts the new layer at the bottom of the layers pile. After that I merge layers, resulting in what you've so clearly explained.
It's much better now, knowing what's going on!
A big THANKYOU for all the answers and explanations.....boy this forum is top notch!!!!
Cheers
Mark
Mark
René ­ Damkot
Jul 30, 2009 04:19 |  #12
Well, what I explained above, applies to "Stamp Visible", not to "Merge Visible".
I think what you are doing is this:
You open an image, edit using adjustment layers, then copy the BG layer. (Cmd+J is faster then drag to the "copy layer" icon ;))
You then run the High Pass filter on the "Background copy" layer, and set blend mode Overlay or one of the other Contrast blend modes.
Then you do "merge visible", and your image changes?
I have tried, but *cannot* duplicate this.
If I take this image (sorry for the garish colors; not colormanaged screenshot), and use "Merge Visible" now, the image stays identical...
IMAGE: http://img.skitch.com/20090730-rxidmkrx86yq2qip77psuqfmbp.jpg
I know I've seen it happen before however, and I think it had something to do with blend modes or clipping masks or so. Cannot remember what it was, and cannot replicate it either.
I'm curious what's happening though.
Can you post a screenshot of your layers palette, or put the .psd online somewhere to download? (small version like 600 px wide is plenty, as long as it's layered)
magal
Jul 30, 2009 07:01 |  #13
René Damkot wrote in post #8367690 (external link)
Yes, you've nailed the process I use exactly. I do use different blend modes in the various layers. What I noticed; when I click edit to undo the last process [after the tranformation], I get told 'undo stamp visible?' even though I'd used the merge visible tab in the first place. The layers are usually curves [normal], vibrance [normal], contrast/brightness [colour] and I end up with the bg copy as described above. Sometimes I might start the process with a reversed gradient [Soft light] and there might be selections that are tweaked in different layers. and sometimes saturation/hue to tweak a certain channel [normal].
Sorry I can't post anything just now - just started my work hitch :( yesterday - 4 weeks in the Sahara desert - at least I got internet ;)
BTW - Is there a thread with all the PS keyboard shortcuts listed?
Mark
Mark
René ­ Damkot
Jul 30, 2009 07:21 |  #14
If you did Cmd+Shift+Opt+e that's "Stamp Visible"
If you did Cmd+Shift+e that's "Merge Visible"
Shortcuts: http://www.photoshopsu​pport.com …r/keyboard-shortcuts.html (external link)
Note: In PSCS3 and PSCS4 you can change a lot of shortcuts. Also, in PSCS4 by default some shortcuts have changed (external link).
magal
Jul 30, 2009 08:38 |  #15
René Damkot wrote in post #8368039 (external link)
Thank you very much for all the help. I'll have a look in the evening after work.
[Should actually be working now but POTN keeps calling me to the w/shop computer ;) for quick peeps]
Mark
1,996 views & 0 likes for this thread, 4 members have posted to it.
1103 guests, 174 members online
