Can anyone recommend a good off camera flash for a cannon 40D
W.E.S.P "Terror Byte" 66 posts Joined Jun 2009 More info | Jul 28, 2009 20:01 | #1 Can anyone recommend a good off camera flash for a cannon 40D canon 40D / canon 17-85mm IS USM / sigma 105mm Macro / Sigma 70-300mm APO DG
Tiberius Goldmember 2,556 posts Likes: 11 Joined Apr 2008 More info | Jul 28, 2009 20:09 | #2 If you are using radio slaves, anything that has a sync port and manual controls will work. My photography website!PHOCAL PHOTOGRAPHY
40Dude6aedyk Goldmember 1,064 posts Joined Jun 2008 More info | I like the Canon 580EXII myself. It's very good. Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
pgruiz123 Member 232 posts Joined Apr 2007 Location: Los Angeles, CA More info | The 580 EXII is a very good flash. I own one myself, but as you are looking for an off camera flash I would not recommend it unless you are willing to invest in the new pocketwizards which retain ettl, radio poppers (which I understand retain ettl), or an off shoe cord like those made by flash zebra http://www.flashzebra.com/products/0125/index.shtml
Strayz Senior Member 691 posts Likes: 1 Joined Oct 2006 Location: Alaska More info | Jul 29, 2009 00:23 | #5 sunpack 383's or nikon SB 26's are my first choices for off camera flashes.. Back to learning after a 5ish year break from photography
canonnoob Cream of the Crop 8,487 posts Likes: 1 Joined Aug 2008 Location: Atlanta, GA More info | Jul 29, 2009 00:30 | #6 430 ex ( I or II) and some cybersyncs.. David W.
Titus213 Cream of the Crop More info | Jul 29, 2009 00:46 | #7 Another vote for the 430EX and Cybersyncs. The reasoning being the 430EX has full manual control for off camera with the Cybersyncs and will still give you a fully dedicated flash to use on camera. And I suspect you will be using it on camera too. Dave
Vineet666 Member 91 posts Joined Jul 2009 More info | Jul 29, 2009 01:17 | #8 Will Skyports trigger the 430ex? Also, will using an off camera flash of any brand other than Canon, harm the camera at all?
Titus213 Cream of the Crop More info | Jul 29, 2009 01:36 | #9 Vineet666 wrote in post #8361116 Will Skyports trigger the 430ex? Also, will using an off camera flash of any brand other than Canon, harm the camera at all? I don't own Skyports but yes, Skyports should trigger a 430EX - but I believe you will need a pc hotshoe attachment for the flash Dave
Vineet666 Member 91 posts Joined Jul 2009 More info | Jul 29, 2009 01:45 | #10 Thanks for the response Titus. So you're saying if I physically do not attach the third-party flash to camera, it won't harm my camera right? I am planning to buy 2-3 flashes for my 40D, all of them I will use off-camera. The SB-E2 is an expensive option for me, considering I already have to buy a Skyport transmitter for my Elinchrom lights which has in-built receivers. I might as well buy another external Skyport receiver and try to use it with 430ex. Could you please recommend some dirt cheap flashes which will work in the slave mode? I will hardly mount those flashes on camera, and if I really have to, I will have one 430ex in that case.
Titus213 Cream of the Crop More info | Jul 29, 2009 09:36 | #11 I'm not up on the available non-Canon flash units available but if you are doing your shooting with them in a studio you may be able to save some money by using optical triggers. Let your Elinchrom light trigger the other units. It's not the greatest but it is pretty inexpensive. If you are not in an environment you control (other photographers around using flash) they will trip your optical units. Dave
Vineet666 Member 91 posts Joined Jul 2009 More info | Thanks Titus, I however want more flexibility with my flashes, to be able to use them outdoors off-camera for portraits etc. I think the best way for me would be go with the skyport receivers with the pc chord link you posted. No other alternate seems more desirable at the moment. I have to narrow on the flashes though, but for now I am more inclined towards the 430ex in the slave mode.
| Latest registered member is ANebinger 1105 guests, 174 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
