Thread started 29 Jul 2009 (Wednesday) 10:49
Brush vignette
weezerfan84
Jul 29, 2009 10:49 |  #1
Does anyone know if I can do a bruch vignette in Photoshop Elements 7? I'm tired of making vignettes with the marquee tool or using that tool and adjusting levels. Want something that I can just brush in area I want darker. Thanks
Canon 5D classic/Canon 85 1.8/17-40L/Siggy 50 f/1.4 ex/430ex speedlite/and some books
My slowly improving flickr (external link)
https://photography-on-the.net/forum/showthre​ad.php?t=735845
Mike
ugly when I'm sober
Gallery: 51 photos
Jul 29, 2009 11:08 |  #2
Does Elements have dodge/burn tools?
or
New layer, black paintbrush and then set the layer opacity to 5% or whatever?
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Jul 29, 2009 11:10 |  #3
What steps are you using to make the vingette? I use the marquee tool, and I find that it is only four steps, takes me about 10 seconds. Perhaps it is a workflow issue.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
tonylong
...winded
Gallery: 60 photos
Jul 29, 2009 11:11 |  #4
Does Elements 7 not have a gradient tool? I've seen that (circular) used to apply vignettes, but I don't use PSE.
Tony
weezerfan84
Jul 29, 2009 11:15 |  #5
Radtech1 wrote in post #8362960 (external link)
Rad
Set foreground to black. Create new layer. Set marquee tool, knock hole to see vignette. Control D to finalize. It's a vignette border. I want more of selected vignette where I can add more vignette on one side but less on another. Saw it on a tutorial online, but it wasn't for PSE. It was for a more powerful Photoshop program. I guess CS3. It had a type of masking that I don't believe I have on PSE7.
weezerfan84
Jul 29, 2009 11:17 |  #6
Mike wrote in post #8362943 (external link)
or
It has dodge and burn options. I just haven't tried it yet. I should try the new layer and black paintbrush to see what happens. That sounds like a good idea.
KEEP THE IDEAS COMING GUYS.
weezerfan84
Jul 29, 2009 11:21 |  #7
Can I continue to make different layers and make a darker vignette on one side and a lighter vignette on the other side? That is, if I try the new layer, black brush, and change opacity. I'm not the sharpest with PSE, but I'm trying.
Mike
ugly when I'm sober
Gallery: 51 photos
Jul 29, 2009 11:37 |  #8
weezerfan84 wrote in post #8363037 (external link)
Yep. Have a play with layers, you can have loads. :D
Gear
UK South Easterners
weezerfan84
Jul 29, 2009 11:39 |  #9
Thanks MIke. I have a busy evening, but I will try this when I get home and see how it comes out. I hope it works out the way that I want it too.
René ­ Damkot
Jul 29, 2009 11:40 |  #10
Black paintbrush (or gradient, or...) on a layer with blending mode soft light or multiply.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
tonylong
...winded
Gallery: 60 photos
Jul 29, 2009 11:46 |  #11
Elements has different ways of approaching things, as does PS. If you are new to layers, a powerful tool to learn to work with is masks.
I know the older version of Elements that I worked with did not have layer masks (ver.4) but you could create a working mask by creating a new layer under the "active" layer then grouping the bottom layer with the acive layer. If you made the "mask" layer empty/erased (not white) it let everything through, if you painted with black it blotted that part of the active layer out. Play with opacity. I don't remember, though, if gray had a "muted" effect or not.
Of course, if Elements 7 has a masking tool then you are all good -- learn to use it!
Tony
weezerfan84
Jul 29, 2009 13:25 |  #12
René Damkot wrote in post #8363162 (external link)
When I make the new layer should I keep it the same as the original or change it's color. That is where I'm a little confused I guess.
Mike
ugly when I'm sober
Gallery: 51 photos
Jul 29, 2009 13:29 |  #13
Same. The colour is just an identifier.
Gear
UK South Easterners
Mark1
Jul 29, 2009 13:30 |  #14
There are several actions that can do it for you. Makes it a 2 click process. Most of them put it on a separate layer so you can control the opacity, color, whatever.
Look here for several free PSE actions.... http://coffeeteaphotog​raphy.blogspot.com/ (external link)
weezerfan84
Jul 29, 2009 13:31 |  #15
Thanks. I'm pretty dumb when it comes to photoshop. I'm slowly getting better at memorizing key strokes.
2,084 views & 0 likes for this thread, 7 members have posted to it.
Brush vignette
Latest registered member is vinceisvisual
960 guests, 176 members online
