Thread started 12 May 2005 (Thursday) 08:05
4 digit file numbers too short?
geoffh
May 12, 2005 08:05 |  #1
I am running an EOS10D and an EOS20D together and am taking so many pics that the file numbers are overlapping leading to big confusion on my hard drive. I have reset one camera to start from 0000 but they overlap again pretty quickly (really). And even if you keep similar file names separated on the disk Sods Law says sooner or later they end up in the same folder.
Long filenames are the answer, preferably a text line prefix in camera (Canon please note). One way is to put a differentiator (e.g. a prefix) on the file name. The 20D allows the folder name to be changed (say 100CANON to 200CANON) using Windows Explorer, which helps slightly, but the 10D recreates the 100CANON folder name whatever you do. In any case the folder name does not get copied onto the PC.
I do all copying by transferring the flashcard. Is there an in-camera way to differentiate? Or which can transfer the folder name too? Or something which allows me to add further info automatically, such as the day/time/session data?
I know this can all be done later in Photoshop but that means sitting down and thinking. My photo sessions (conferences, football matches, carnivals) seem to demand rapid transfer of large numbers of files on the spot, so thinking is not good ... and losing files due to duplicate filenames is even worse!
S230
May 12, 2005 08:31 |  #2
Not sure about the 10D and changing on the spot but as for offline, I had ran into this problem 2 years ago and since then I had been using a date convention. What I would do is rename the IMG_xxxx to let's say this month to 0505xxxx (x's are the file number).
I keep the digits to 8 digits becasue incase of compatibility issue. As for naming per month, the chances of duplicating within a month is minized unless you take more than 9999 a month. In this case, just add extra letter to end. With my S230 camera, i have over 30000 photos on it and you can imagine if I had to search for a unique number.
Personally when I do it onsite, i generally use different CF cards and when after a session I backup onto my PD7X which creates a new folder for every transfer.
Hope this helps.
My gear: Lots of bodies...
Lenses: Bunch of different metal tubes with glass in them... :)
ProAc_Fan
May 12, 2005 08:31 |  #3
Batch renaming in photoshop really isn't all that time consuming. I mean, hell, you give the files a name, select the numbering order and the software does all the work in seconds.
Mike
jyrgen
Joined Aug 2003
May 12, 2005 08:38 |  #4
I use batch rename in BreezeBrowser right after downloading the files to the computer (I download them with ZoomBrowser, which is configured to create folders according to shooting date). I have configured BreezeBrowser to prefix the shooting date to the said four digits, but one can configure it to form the file name from many different system variables or constants, including those from exif, like aperture value or ISO.
Canon 35/1.4 | Canon 50/1.4 | Canon 135/2 | Canon 17-40/4 | Canon 24-105/4 | Canon 70-300/4.5-5.6
Canon 5D | Canon Speedlite 430EX | Manfrotto 055 ProB + 488RC2 | Kenko ext tubes & 1.4x TC
S230
May 12, 2005 08:46 |  #5
Just to add, to batch rename for canon files can be done straight in command mode.
for both Win98, Windows 2000 and XP, you can copy using explorer into a directory. let's assume c:\temp
click on Start and select run
type in "command" or "CMD"
in dos prompt, you change directory to the temp folder.. "cd \temp"
from there is where all the files are located. You type in:
this will almost instantly rename all files leading with IMG_ to the year and month you specified. This is much more direct approach than using any fancy applications.
hope this helps. :)
aam1234
Joined May 2004
May 12, 2005 09:31 |  #6
Don't know if this is applicable or not, using ZoomBrowser to dowload, it asks you to give a prefex. That's why I prefer ZoomBrowser for downlaoding.
Longwatcher
obsolete as of this post
Joined Sep 2002
May 12, 2005 09:37 as a reply to  @ aam1234's post |  #7
You obviously need to upgrade just for that. :D
My 1DsMkII has a unique file name coming out the camera that I can't change if I wanted to until it gets on my computer. "VI0S_####" for trivia (although if in Adobe RGB it will be "_I0S_####" )
It is actually both good and bad and I personally would prefer to be able to change it as needed, but on the other hand it does prove RAW pictures are from MY camera.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
S230
May 12, 2005 09:56 |  #8
For file naming convention, I personlly don't like the way Canon had created it. What is worst is that if you use the same flash card and put it into another canon camera, it would reset the filenumber on the other camera or vice versa. I run into this problem quite often and is fustrating. (Don't share flash card between Canon cameras).
I haven't really experienced too much with higher models of Canon but with the Nikon D70 don't seem to have this problem. They can create a folder within the camera and place photos as they take them within that ONE folder until user chooses to create another one. Wished Canon would had thought about that option. Unless somebody can come up with a new firmware hack that can incorporate this function.
karusel
Joined Nov 2003
May 12, 2005 10:33 |  #9
How curious... Apparently there haven't been enough heavy shooters complaining about this, as I'm sure Canon could fix that in a second, say, add another #, or while tey're at it, two ##.
5D and holy trinity of primes. Now the 90mm TS-E TS-E fly bit me. I hate these forums.
Digital ­ Prophet
Joined Apr 2004
May 12, 2005 11:02 |  #10
I know that I am criminally insane. But I have a file naminq system that I use that not only stops overlap but also makes image identification easier.
It is made of a 13 digit alpha-numberic system based on:
  • Purpose of the photo (i.e. personal, stock, sale, online use etc.)
  • Category of photo (i.e. Horse and Rider, Architecture - General, Arcitecture - Interior, Commissioned City Project etc.)
  • Camera used (300D, RB67 etc.)
  • Location (Name of Ranch, Houston - Downtown, Houston - Zoo etc.)
  • Format photo was shot in (Raw, JPEG)
  • Subject (Client name, Project number)
  • And finally a four digit image number
Sample file name: C31-A05-A31-0001.JPG
That tells me that it is a Sale Photo that was shot for the City of Sugar Land shot with my 300D at the Sugar Land Regional Airport in RAW format and it is a Miscellaneous Group Photo and that it is the first one in that category.
I have been using this system for over a year and have been so pleased. It seems complicated but batch renaming makes it so easy in BreezeBrowser and over converters. And I can't tell you how many times I have had someone call for an image and how fast it is to find this way.
Try it, you might find out you are insane too.
- Digital Prophet -
Canon 300D, Canon 5D and some glass and some stuff.
"Your cooking makes me question my faith." - Bucky Katt
OviV
Joined Oct 2003
May 12, 2005 11:19 |  #11
Try my free utility that I wrote for my use and have shared with others. It will put files in separate folders by camera model and can prepend photographer's initials to file names.
https://photography-on-the.net/forum/showthre​ad.php?t=43292
5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
Sicily1918
Joined Jan 2005
May 12, 2005 11:21 as a reply to  @ Digital Prophet's post |  #12
Hmmm... I generally create a directory with the subject (e.g. "San Diego" or "Beach" or "Milliways") and dump all the xxxCANON directories in there -- I never worry about file overlap because they can't.
As for the numbering system, CF cards (most NV RAM media for that matter) work on FAT, which is limited to the 8.3 naming convention. If they're gonna call it "IMG_" you only have 9999 numbers to use (since they don't use 0000). I suppose they could call it CA (for Canon) or DG (digital) and add a dash, that'd give us 100,000 numbers (CA-xxxxx.JPG); surely more than enough? ;)
Canon 50D
Canon EF 50mm f/1.8 II | Canon EF-S 10-22mm f/3.5-4.5 USM
Canon EF 24-105mm f/4L IS USM | Canon EF 100-400mm f/4.5-5.6L IS USM
Canon BG-E2 Battery Grip | Canon Speedlite 580EX and 420EX
karusel
Joined Nov 2003
May 12, 2005 11:23 |  #13
digital prophet: Wow, so.. you're off your pills for over a year? :lol:
I wanna be insane too, but the tutorial you provided doesn't help. Requesting detailed instructions. What's C31?
Also, I have a similarly insane idea for those who don't shoot for clients: go through all your photos, pick out the best, copy them in one folder (or two if numbers are naughty and overlapping), go through them again, force yourself to dump 50% of the not-so-good ones. If you're like me, you'll have a pretty thin folder and no trouble renaming every file to a text description. :D
Jon
Joined Jun 2004
May 12, 2005 11:31 |  #14
Like many others, I rename mine in batch. Format's aaa-bbbb_cam.*, where aaa is the camera's folder number; bbbb's the file number from the frame, and cam is 20D, D60, A80 as appropriate. So a typical file would be 160-6023_D60.JPG.
Jon
Cocker Spaniels
iwatkins
Joined Sep 2003
May 12, 2005 11:41 |  #15
Get yourself a copy of BreezeSystems Downloader Pro, it'll do it all for you.
Once setup you just plug a CF card into the card reader and away it goes.
I currently only have the one camera, so Downloader Pro is currently configured to name mine as follows:
\Year\Month\Negatives\​Day\yyyymmdd_hhnn_seri​al.crw
E.g.
\2005\05\Negatives\12\​20050512_1752_9678.crw
File name is year, month, day _ time _ serial number
Downloader Pro even creates the directories for you as it goes along. I've even got it configured to create my other working directories for me at the begining of each month, e.g.
\2005\05\Negatives\
\2005\05\PrintReady\
\2005\05\WebReady\
For your problem it can also tag each image with a unique reference based on the camera body.
Worth a look
Cheers
Ian
5,803 views & 0 likes for this thread, 22 members have posted to it.
1888 guests, 105 members online
