Thread started 01 Aug 2009 (Saturday) 06:40
settings for surf photo?
Justin ­ Holl
Aug 01, 2009 06:40 |  #1
hey, to who here shoots surf,
jus asking what would be the best settings to use for surfing in bright daylight on a canon 350d?
DAUMO
Aug 03, 2009 20:32 |  #2
id like to know also
5DMK II | 24-70L | 50mm 1.8 MKI | 430EX | 580EX II
SurfKahakai
Aug 03, 2009 21:52 |  #3
Full daylight: ISO 100 - f5.6 - 1/1250th
Those are generic settings. Play around from there.
Prescott, AZ
www.benquesinberry.com (external link)
Justin ­ Holl
Aug 04, 2009 05:45 |  #4
SurfKahakai wrote in post #8394039 (external link)
thanks mate, ive jus been using sports mode hehe seeing i dont know much hopefully this will go better.
thanks
hooookup
Joined Nov 2005
Aug 07, 2009 09:52 |  #5
Exactly.
You can also try iso100 f8 1/800"
silvex
Gallery: 21 photos
Aug 09, 2009 02:26 |  #6
None of these setting will freeze action. The starting point is 1/500 as a BARE minumum 1/1250 being the one to get water crisp. I suggest manual exposure. Start with the widest aperture the lens can take. The adjust shutter speed until the "needle" is in the middle while focusing on the water. Then decide how much of the "white" portion of the water will be blown. Then shoot away. If you can get 1/1250 then start bumping ISO from 100-400-800.
Good luck.
-Ed
CPS Platinum Member.
Canon Gear
SilvexPhoto.comexternal link
ChunkyDA
Gallery: 17 photos
Aug 18, 2009 21:31 |  #7
I'm not the surf pro photog but here are some suggestions:
Longer telephoto=better shots
AI Servo focus mode. Center point focus. Widest aperature your lens will allow. faster that 1/1000 shutter. Set a bit of overexposure in camera, the meter will try to make 18% gray and the surf is probably white.
Keep your lens and camera out of the salt spray as best as possible. Bring a lens pen or some other quality lens cleaner to wipe the spray off the lens every now and then.
Keep the sand away from everything. Bring a towel, chair, or something to set your stuff down on.
Bring a hat or something to block the sun so you can see the histogram.
Pay attention to where the sun is and which way the waves break, try to avoid backlighting and surfers backs, you want face. Shot #2 would probably wind up in the delete pile.
#1 Below is not cropped, just resized, 200mm + 1.4TC on 1.3 crop body
1/1600 f4 ISO 100
Dave
Support Search and Rescue, Get Lost (external link)
Gear list and some feedback
Jaewhy
Aug 20, 2009 18:21 |  #8
yes, a good starting point
silvex wrote in post #8425679 (external link)
Good luck.
not sure i agree with this approach. i would stick with the 1/1250th - f5.6 - ISO 100 to keep things simple.
BLOG (external link) * MAIN (external link) * FLICKr (external link)
orena
Joined Sep 2009
Sep 28, 2009 09:11 |  #9
[QUOTE=SurfKahakai;839​4039]Full daylight: ISO 100 - f5.6 - 1/1250th
Those are generic settings. Play around from there.[/QUOTE
+1
Always do right, this will gratify some people and astonish the rest.
5DIII-7D-70-200L 2.8IS II-24-70 2.8 II L -50 1.4--28 135(4 SALE)-580exii-430ex -
http://www.orenaphoto.​com (external link)
4,658 views & 0 likes for this thread, 8 members have posted to it.
2890 guests, 140 members online
