Thread started 05 Aug 2009 (Wednesday) 02:24
EF-S on 1d mk3 1.3crop?
Whippeticious
Aug 05, 2009 02:24 |  #1
the heading asks the question, can you use EF-S lenses on the 1D?
EagleRock
Aug 05, 2009 02:25 |  #2
No, You can only use EF lens.
Vascilli
Aug 05, 2009 02:27 |  #3
You can use some (10-22mm) with a touch of modifications. Third party lenses usually work too because they actually have an EF mount.
Flickr (external link) | Gear List
SkipD
Joined Dec 2002
Aug 05, 2009 03:32 |  #4
Whippeticious wrote in post #8401745 (external link)
Believe me - if you have to ask this question, you do NOT want to try any of the mods that would allow you to adapt EF-S lenses to a 1D (or any other camera not specifically designed to use EF-S lenses).
Skip Douglas
Rendition
Aug 05, 2009 03:43 as a reply to  @ SkipD's post |  #5
Even if you successfully mod it to fit, heavy vignetting will show up at wide end. The only body to mount to that's worth modding is 10D as it's 1.6x but it doesn't take EF-S.
// visualverve (external link) //
Canon EOS-1Ds Mark III + WFT-E2 II ❘ 5D Mark II
17-40L ❘ 24-70L ❘ 50L ❘ 70-200 f/2.8LIS ❘ 2X 580EXII ❘ 2X CP-E4
Elinchrom BXRi ❘ Velbon Neo Carmagne 640A
Vascilli
Aug 05, 2009 03:47 |  #6
The 10-22mm in particular is pathetically easy to modify. All you have to do is pull off the black plastic baffle from the rear and make sure you don't zoom wider than 12mm or else the rear element will be hit by the mirror. You don't even need any tools and there is virtually no vignetting.
bluefox9er
Location: UK,don't move ehre,it rains a lot, it's incredibly violent and the women pee standing up..
Aug 05, 2009 06:23 |  #7
why would you want to do this? if you have a pro camera, put some decent glass on it.
http://www.flickr.com …s/sets/72157602​470636767/ (external link)
http://www.flickr.com …ctions/72157604​292148339/ (external link)
Canon EOS 1d mk III, Canon EOS 5d,Canon EOS 400d, 24-70 mm F2.8 L, ef 24-105 F4 L IS, ef 17-40 mm F4 L, 70-200 mm f2.8 IS L, 100-400 mm IS L, 50mmm f1.8, 85mmf1.8mm, ef 35 mm f1.4L, ef 135 mm f2 L,Canon Powershot G9, Epson p400-, hyperdrive space 120gb
mbellot
"My dog ate my title"
Aug 05, 2009 08:34 |  #8
bluefox9er wrote in post #8402248 (external link)
Cheap macro.
I modded my (unused) 18-55 so I could mount it on my 1DIII.
I set the aperture, hit DOF preview, unmount the lens while its stopped down and remount it reversed.
18mm reversed on the 1DIII is an awful lot of magnification, and no vignetting.
:D
(Before doing the mod I had to use my 20D to stop down the lens)
Wilt
Aug 05, 2009 09:04 |  #9
Vascilli wrote in post #8401939 (external link)
"Danger, Danger, Will Robinson!"
Whippeticious
Aug 05, 2009 18:12 |  #10
I haven't got one, I was just asking FFS.
Luke ­ Cern
Joined Jan 2005
Aug 05, 2009 18:22 |  #11
Whippeticious wrote in post #8406354 (external link)
Once a question like this is posted, nothing stops members chipping in with ideas. It's the nature of the beast that is a worldwide forum!
______________
Torquay Devon UK
5D MkII , 300mm f/4 L IS, 135mm f/2.0 L, , 24-105 L IS, 180mm Sigma Macro, 100mm f/2.8 Macro, 15mm Fisheye, Sigma 12-24mm f/4.5-5.6, TC, Gitzo G1298 Basalt. 580EX MKII, 430EX, ST-E2.
gasrocks
Aug 05, 2009 21:12 |  #12
No danger, no fancy mod needed to use the ef-s 10-22 on a MK III. I did it with great results. Put your finger inside of the rear plastic baffle on the lens and pull it off - it just snaps into place - can be easily replaced. Now your 10-22 will mount on your MKIII. If and only if you do not see dark edges in the viewfinder (about 15-22mm) you can safely use it.
NicolasRubio
Aug 05, 2009 21:18 |  #13
You can replace the plastic buffle with the one of the EF 24-85mm so that the lens is still protected. Someone in this forum did it!
Gripped 7D - 3 Ls - 3 non-Ls - 580EX II - Too much Think Tank gear - Cotton Carrier Holster
Detailed Gear List - My Website (external link)
Vascilli
Aug 05, 2009 22:41 |  #14
Wilt wrote in post #8402930 (external link)
It did happen to me, the mirror obviously didn't lift all the way and by the time I found out what went wrong and fixed it, the picture was a mess of blown out and totally black areas. No serious damage will happen but I'd still avoid it.
bluefox9er
Aug 06, 2009 07:04 |  #15
waits for the " omg i have totally f****d up my 1dmkIII by mounting an ef-s lens on it " posts to come rolling in...
seriosuly...wouldn't it be easier all round if you mounted an ef-s lens on a camera that accepts an ef-s mount??
5,226 views & 0 likes for this thread, 17 members have posted to it.
887 guests, 133 members online
