FORUMS Marketplace & Market Info Market Watch
Thread started 11 Aug 2009 (Tuesday) 04:46
UK: Sigma 70-300mm f/4-5.6 DG Macro (Canon AF) £89.00 Jessops
UK_Tomcat_Fan
Aug 11, 2009 04:46 |  #1
http://www.jessops.com …n%20AF%29-26774/Show.html (external link)
High performance lens optimized for use with digital SLR cameras
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2.SLD (Special Low Dispersion) glass in this lens provides excellent correction of chromatic aberration.
Coating reduces Ghost and Flare
The multi-layer lens coating and lens design reduce flare and ghost, which is a common problem with digital cameras and also creates an optimum colour balance through the entire zoom range.
SLD (Special Low Dispersion) glass is used in this lens for correction of chromatic aberration. This also corrects for fluctuation of aberration due to focusing. High optical performance is demonstrated throughout the entire zoom range.
Macro shooting with maximum magnification 1:2
This lens is capable of macro photography with a 1:2 maximum close-up magnification at the 300mm focal length. The minimum focusing distance is 1.5 m at all zoom settings. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2 and a minimum focusing distance of 95cm. Without changing the distance between camera and subject, you can change the shooting magnification.
Specifications:
Lens Construction: 14 Elements in 10 Groups
Angle of View 34.3degrees - 8.2degrees
Number of Diaphragm Blades: 9 Blades
Minimum Aperture: f/22
Minimum Focusing Distance: 150cm / 95cm(Macro mode)
Maximum Magnification: 1:4.1 / 1:2(Macro mode)
Filter Size: Diameter 58mm
Dimensions: Diameter 76.6mm x Length 122mm
Weight 545g
Martin | GearList | Website: My photography (external link)
POTN Resident Jolly Roger / Super bug hater!
95 views & 0 likes for this thread.
1907 guests, 105 members online
