Thread started 12 Aug 2009 (Wednesday) 23:40
seriously pissed off camera flash question (wired & infra red mixed)
enginyr
Aug 12, 2009 23:40 |  #1
Does wired sync work with on camera flash? It seems as if my on camera 580ex2 is throwing the sinc wire out of wak.
5d2 hooked up to a strobe thru the sync port on the side of the camera
5d2 hooked up to a strobe thru the synn port on the side of the 580ex2
5d2 " " with the flash off is the only way I could get it to work.
LA Wedding photographer (external link) Stunning Bride Photographers.
Austin.Manny
Aug 12, 2009 23:45 |  #2
I'm pretty sure the sync port on the 580exII is for input only, you can't use it to trigger another flash/strobe. :confused:
1D Mk III | 450D Gripped | Σ 30 f/1.4 | 85 f/1.8 | 18-55 IS
Canon 430exIII | LumoPro LP180 | Yongnuo YN-460 |
RF-603
enginyr
Aug 13, 2009 01:31 |  #3
thank you austin. It seems as if my strobe has an internal optical sync that just won't turn off even when trigger thru a wire, is the problem.
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Aug 13, 2009 02:24 |  #4
As you do not refer to the 550EX and 430EX in your tests, I assume they are not in use at the time and are not part of the configuration.
Camera sync port to off-camera 580EXII sync port should fire the flash, unless the flash is in Master and Manual mode, in which case the port is disabled.
I would expect problems if a 580EXII is placed on-camera, and also has a pc-sync cable from camera to flash - I know of no benefit in the redundant connection. Have you tried that configuration?
Turning the main flash Off is possible only when in Master Mode. It requires a full E-TTL connection to be in use (hot-shoe, Canon extension cable). If it is off, in what way did "it work"?
As Austin.Manny says, the 580EXII sync port is input only, and only when in the right modes. A cable running from a 580EXII port to say, a 550EX will not fire the 550EX.
There is no optical sync capability in the 580EXII. The Canon command/E-TTL system uses an optical carrier, but is not a simple optical trigger. A PC-sync cable can be used in a "hybrid trigger" configuration under very specific settings.
Perhaps a more useful response could be given if you said precisely what configuration you are trying to achieve.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
1,063 views & 0 likes for this thread, 3 members have posted to it.
1026 guests, 119 members online
