Thread started 13 Aug 2009 (Thursday) 11:16
72mm to 77mm
alt4852
Aug 13, 2009 11:16 |  #1
Just out of curiosity, does anyone use 72mm to 77mm step up rings with their 24L? I plan on getting:
http://www.bhphotovide​o.com …72mm_to_77mm_St​ep_Up.html (external link)
for use with my 35L and eventually a 24L and 85L because all of my expensive filters are 77mm. I don't feel like dropping hundreds of dollars to get redundant filters for the smaller filter sizes, so I was wondering if use of neutral density or non-slim circular polarizers will cause vignetting on the 24L. I figured the 77mm should offer some more latitude in it's extra diameter to reduce the chance, but if there are any first hand users, I'd really appreciate some input. Thanks in advance!
5D4 | Z21 | 35L2 | 50L | 85L2 | 135L
ToyTrains
Aug 13, 2009 12:54 |  #2
I tried this on another lens and found the lens hood couldn't be removed without removing the filter. I ditched the step-up and got another set of filters :(
SkipD
Joined Dec 2002
Aug 13, 2009 18:36 |  #3
ToyTrains wrote in post #8453471 (external link)
The above is precisely why I wouldn't even dream of using step-up rings. I always use a lens hood and would not do anything that would prevent that from being possible.
Skip Douglas
NYPhotog
Aug 13, 2009 20:59 |  #4
I use step-up rings all the time, primarily when shooting off a tripod. I simply shield the lens from the sun with something, such as a hat. No problem.
alt4852
Aug 13, 2009 21:32 |  #5
yea, i thought about that.. i'm still trying to figure out how much of an issue it will be as i won't have the filters on my primes all that often. it's more or less an option i want when i'm packing light and will probably be carrying the 24L, 35L, and 85L while leaving my zooms at home.
SkipD wrote in post #8455396 (external link)
yea, i religiously use lens hoods too, but if you think about it, you can't use hoods with a CPL anyways. unless there's a massive threat of flare, adjusting a CPL and then mounting the hood before taking a shot is just too much trouble for me most of the time. using a circular polarizer is the only time i really shoot without a hood because it's too much hassle to make adjustments. if you have a technique that allows you the ability to manipulate a CPL with the 24-70, 70-200, etc hood attached, i'd love to learn.
thanks for the input everyone. if anybody out there has any other opinions, i'd really appreciate some more words of wisdom!
SkipD
Joined Dec 2002
Aug 13, 2009 22:58 |  #6
alt4852 wrote in post #8456206 (external link)
I do it all the time.
With the 24-70, it's super-simple. Just zoom to the short focal length temporarily and you can easily reach the filter for adjustment.
With the 70-200 f/2.8L IS, I can reach into the hood to tweak the filter if I need to. However, it's easier to temporarily remove the hood (with the filter still attached), adjust the filter, then put the hood back on.
Skip Douglas
alt4852
Aug 13, 2009 23:43 |  #7
SkipD wrote in post #8456672 (external link)
hmm, i'll have to give it a shot sometime. it only seemed practical to do that sort of thing if i was tripod mounted. hand-holding the 70-200 while stuffing my hand into the hood and holding my camera/lens steady with the other hand takes a bit of manual acrobatics which i always figured to be way more trouble than it was worth.
GMCPhotographics
Gallery: 92 photos
Aug 14, 2009 04:38 |  #8
I use a hood purely as a lens protector, nothing else. At 24mm, that skimpy hood isn't going to shield much against flare. The angle of view is so wide, I don't really see the need for a hood other that to protect the lens from scuffs. It's like the hood for a 16-35/17-40L, completely pointless in my opinion.
If you need to use a filter then ditch the hood, or put it on a tripod and use a remote release and use your hand over the lens to reduce flare/glare/ghosting etc.
Besides, since Lost and the last Star Trek film, lens flare is back in Vogue.
Regards, Gareth Cooper GMCPhotographics
"If youre happy and honest and fulfilled in what you do, then youÒ’re having a successful life" (Ben Elton)
Gear List GMCPhotographics (external link)
1,035 views & 0 likes for this thread
72mm to 77mm
Latest registered member is despedidasolte
795 guests, 183 members online
