Thread started 14 Aug 2009 (Friday) 15:49
Single 4x4 (100mm) filter holder that attaches to the front of a regular filter
John_TX
Aug 14, 2009 15:49 |  #1
I ran across this at B&H today while looking into the Lee 4x4 (100mm) filter holders: I really just need something to hold one 4x4/4x5 filter in front of the lens.
http://www.bhphotovide​o.com …rass_Filter.htm​l#features (external link)
  • Heliopan 706107 Heliopan Rotating Filter Holder 105MM.
  • The 105mm Heliopan rotating filter holder is made from brass and has a matte black finish.
  • It is intended to be used with Heliopan rectangular 4'' wide (100mm) glass filters up to 4mm thick.
  • It is threaded in the front to accept additional filters, lens hoods or to combine multiple holders for special effects.
  • It combines the ability to both rotate and alter the position of graduated filters.
I've been looking for an inexpensive way to use one 4x4/4x5 filter with a polarizer, but unfortunately, this is turning out to be a rather expensive endeavor!
- $75 Lee Foundation Kit
- $60 Lee Wide Angle Adapter Ring
- $52 Lee Accessory Front Thread Adapter Ring (105mm)
- $219 B&W CPL
- $125 for two Hitech soft GND (0.6 & 0.9) 4x5 filters
$531
The Heliopan rotating filter holder (above) that attaches directly to the front threads of your filter seems perfect...but what the hell is up with the cost? :evil: $400 bucks for a 105mm ring that simply rotates??? These guys are nuts!
Besides the $400 cost, this seems like the perfect way to put a 4x5 filter in front of a 77mm polarizer already attached to your lens. It appears that you would only need the Heliopan rotating filter holder and a 77-105 step-up ring. This would allow you to use all of your preexisting 77mm filters along side any of the 4x5 filters.
Does anyone know if someone else makes a similar setup? Hell, I don't care if it's a durable plastic. $400 seems really extreme when you could buy a 105mm CPL, knock out the glass, and attach some clips to the front to hold the 4x5 filters...all for way less than $400 and it would still rotate independently of the CPL attached to the lens.
5D4 | 5D3 | 16-35 f4 IS | 24-105 f4 IS | 70-200 f4 IS | 100-400 II | Sigma 20 f/1.4 ART | Sigma 35 f/1.4 ART | EF 1.4x III | EF 2x II | 430EX II |
argyle
Aug 14, 2009 16:20 |  #2
Seems like an unnecessary and expensive approach. See my response in your other thread.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Aug 14, 2009 19:36 |  #3
That attaches to a filter holder so with a step up ring all you would be able to do is to attach a 105mm CPL.
John_TX wrote in post #8460713 (external link)
- $219 B&W CPL
$531
Doc Klepper in the USA
I
NYPhotog
Aug 15, 2009 01:02 |  #4
Like everything else that Heliopan sells, it expensive beyond reason. BTW, the only company that has a 77-105mm step-up is, you guessed it, Heliopan and it costs $67.
John_TX
Aug 15, 2009 01:18 |  #5
NYPhotog wrote in post #8462900 (external link)
Of course! You'd think with the price of their products, they could put up a website with all their products...nope.
4,034 views & 0 likes for this thread, 4 members have posted to it.
Latest registered member is monmon
460 guests, 197 members online
