Thread started 16 Aug 2009 (Sunday) 00:22
10-Stop Neutral Density Filters: 4x4 Resin or 77mm Screw-on ?
John_TX
Aug 16, 2009 00:22 |  #1
What's the best format of Neutral Density filters to use? 4x4 square resin filters like Lee/Hitech or a standard 77mm screw-on ND filter like those made by B+W?
I'll be ordering a Lee holder once they come back in stock, so initial setup costs aren't a concern. Currently, I'm leaning towards the 4x4 resin option, but am interesting in learning more about the potential of stray light entering in around where the filters and holder meet (and if this makes any difference at all during long exposures (2-10 minutes)).
I've heard pros & cons for both setups:
4x4 resin ND filters:
-Pro: Easy to use (simply lift up the filter to compose/focus)
-Con: For long exposures, I've read that stray light can sneak in along the sides???
Screw-in ND filters:
-Pro: No light leakage for long-exposures
-Con: Kind of a pain to work with as you've got to constantly screw on & off the filter as you set up each shot.
5D4 | 5D3 | 16-35 f4 IS | 24-105 f4 IS | 70-200 f4 IS | 100-400 II | Sigma 20 f/1.4 ART | Sigma 35 f/1.4 ART | EF 1.4x III | EF 2x II | 430EX II |
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Aug 16, 2009 07:56 |  #2
I'm just researching this myself, so to list another con of the flat filters: You can't use a lens hood, so flare can be an issue. I have heard of "hoods" that you can put on the front of a flat filter system, but that seems to adds a level of difficulty because now you have another thing to put on and take off. And purchase.
Another con: The flat filter system means more stuff to pack. And their more difficult to pack.
Another pro for the flat system: They're easier to stack, with no issues with vignetting. So if you have a 10-stop and a 4-stop it's easier, and better for the picture, to get 14 stops by stacking. Vignetting can occur when doing this with screw-in filters.
I've decided on the screw-in, mainly because I like to travel light.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
NYPhotog
Aug 16, 2009 08:24 |  #3
Lee has several hoods for their system that you can use in conjunction with the holder or attach directly to a lens via an adapter ring. I use a WA hood that has two regular filter slots and a built-in retaining ring for a 105mm CPL (I use a B+W Kaeseman), so I do not even need to use the holder. Also, many choose to hand-hold these filters, as I sometimes do, which makes these filters even easier to use.
The "flat" filters are actually easier to pack. I use the Lee filter wallet, which holds 10 4x6" filters and takes up less space than would 10 screw-in, round filters.
Vignetting is definitely an issue when using the "flat" filters, because the holder slots have thickness. The filters don't cause vignetting, the holder does.
And, of course, the primary reason for the existence of 4x6" filters is for the GND filters. As has been discussed here many times: round, screw-in GND filters are next to worthless because the transition line of the filter is always dead center of the frame, which is where you must always place the horizon.
EdBray
Aug 16, 2009 08:34 |  #4
Scottes wrote in post #8468261 (external link)
Why on earth would you want a 14 stop filter?
If your exposure without filter was 1/125 @ f8 @ 100 ISO, a 10 stop filter would give you 8 secs @ f8 and a 14 stop would give you 2 mins @ f8
If you use a square filter system, you have to somehow ensure that there is no light leakage between the filter and holder as due to the excessive change in exposure from the filter's use any leakage will affect the contrast and quality of the result.
Canon EOS 5DMkII, Canon EOS 10D, Canon EF17-40L, Canon EF24L TS-E MkII, Canon 24-105L IS, Canon 70-200L f4 IS, Canon EF 1.4x Extender MkII. Hasselblad 503CX, Hasselblad 500CM, Carl Zeiss 40mm, 50mm, 80mm, 150mm, 250mm For my epitaph: Do not let my wife sell any of my kit for what I've told her I paid for it! My Flickr (external link)
Jon
Joined Jun 2004
Aug 16, 2009 08:35 |  #5
The other advantage to the flats is that you'll be wanting graduated NDs somewhere along the line, and screw-in is not a viable option for those, so you'll need the slotted holder anyhow.
EdBray wrote in post #8468382 (external link)
Making people disappear in a cityscape, for one.
Jon
Cocker Spaniels
EdBray
Aug 16, 2009 08:38 |  #6
Jon wrote in post #8468386 (external link)
You can do that with a 10 stop. Just lower the ISO and/or close down the aperture!
EdBray
Aug 16, 2009 08:41 |  #7
If you use a square filter system, you have to somehow ensure that there is no light leakage between the filter and holder as due to the excessive change in exposure from the filter's use any leakage will affect the contrast and quality of the result. How do you light seal the filters in the holder when stacked?
Scottes
Joined Nov 2003
Aug 16, 2009 08:42 |  #8
EdBray wrote in post #8468395 (external link)
Sometimes you don't want to, sometimes you can't. I can't go lower than ISO 100, and I don't want to get diffraction problems by going to f/22.
Obviously, YOU have other ideas. So do them, or not. Whatever.
Scottes
Joined Nov 2003
Aug 16, 2009 08:43 |  #9
EdBray wrote in post #8468403 (external link)
Gaffer tape.
Scottes
Joined Nov 2003
Aug 16, 2009 08:47 |  #10
NYPhotog wrote in post #8468358 (external link)
I can't see how this is possible, since the flat filters have so much more area. A 77mm filter has 2000 square millimeters of area. A 4x6" has almost 16,000 square millimeters of area. It seems that 10 4x6s will take up a lot more room.
Not trying to argue, just trying to understand since I'm not experienced with the flat filter system. And the holder has to take up a decent amount of room, too.
Jon
Joined Jun 2004
Aug 16, 2009 08:54 |  #11
If you've got a 4x6, you're talking a grad. And there's no way I'm going to let the filter decide my composition for me, like a screw-in grad would force me to do.
Solid NDs are 4x4. And remember, those square filters are only 2 mm thick. How thick is your 77 mm screw-in? And do you stack them without a case, just end caps, or do you keep them in a case? If the latter, you need to allow for the size of the container. If the former, the convenience or not of unscrewing the needed filter from the stack vs. sliding one out of a case.
Jon
Cocker Spaniels
Lazuka
Aug 16, 2009 13:22 |  #12
i just ordered an 8 stop flat, i'll let u know how that goes ;)
I suck at Photoshop.
NYPhotog
Aug 16, 2009 14:08 |  #13
Lazuka wrote in post #8469519 (external link)
Which filter?
CronoDL
Aug 16, 2009 16:19 |  #14
One thing to consider - you'll probably be focusing manually, or at least without the filter since AF likely won't work with a 10stop ND, and the VF will be pretty dim if it's on the lens. That means there's a good chance that you focus without the filter, and then slap on the filter when you're ready to take the shot. A slip-in filter might be less annoying than having to screw in a round filter when it comes time to take the shot.
Danny
500px (external link)
Lazuka
Aug 16, 2009 18:25 |  #15
NYPhotog wrote in post #8469727 (external link)
Which filter?
cokin, cause i'm cheap ;)
9,316 views & 0 likes for this thread, 11 members have posted to it.
Latest registered member is monmon
587 guests, 187 members online
