Thread started 16 Aug 2009 (Sunday) 08:45
Just got my 70-200mm f.4L - Need opinions please!
Justiss
Aug 16, 2009 08:45 |  #1
What do you think of these shots? Did I mess up on settings, or was it my poor lighting choices? I am not overly impressed and I want to get some better photos out of the lens...It could definitely be operator error! :oops: What should I do next time?
IMAGE: http://i101.photobucket.com/albums/m66/kjustiss/40DVacationVero2009683.jpg
exif: 180mm, f/4, 1/320
IMAGE: http://i101.photobucket.com/albums/m66/kjustiss/40DVacationVero2009708-2.jpg
exif: 70mm, f/7.1, 1/1250
IMAGE: http://i101.photobucket.com/albums/m66/kjustiss/40DVacationVero2009360.jpg
exif: 200mm, f/5, 1/800
I shoot in AV most of the time, just because that is where I'm most comfortable. With kids moving so quickly, I find it hard to change settings and keep up. Any suggestions are more than welcome! Thanks!
Kathryn
Flickr (external link) Website (external link)
gasrocks
Aug 16, 2009 08:50 |  #2
What don't you like about those shots? Many people would be proud of them.
gjl711
Aug 16, 2009 08:51 |  #3
Same question, what do you perceive as a problem. They look pretty good to me.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
JustinTEleven
Aug 16, 2009 08:58 |  #4
Hi,
The first photo is very nice in my opinion but what is the ISO on the second two? I only ask because the appear to be quite noisy. With the second photo, it could be an extremely nice shot with a flashgun to light your subject AND either a higher f-stop or lower to create a better blur or reduce the blur in the background. Photo 3 is a nice candid shot so I can't say anything other than the noise comment but I would have tried to shoot this with the lens wide open to further take attenion away from the background.
Thanks,
Justin
Yaamon
Aug 16, 2009 09:13 as a reply to  @ JustinTEleven's post |  #5
It's hard to say, I would say normally the 70-200 should have a better contrast, colors and detail than that.
It all depends on the time it was taken ealry morning sun does not have that much contrast or late evening.
I took this with the IS lens at 192mm at F4 and iso100. Shutter speed of 1/500th, this is with no post processing raw to jpeg using dpp.
Make sure that in the camera its set for sRBG and try the standard picture profile setting.
IMAGE: http://farm3.static.flickr.com/2608/3805968877_f1eaae4f70_o.jpg
Skrim17
Aug 16, 2009 09:19 |  #6
did you shoot raw? Any editing at all?
Since you have image editing turned on, all I did was boost the saturation and contrast, then sharpened.
IMAGE: http://i4.photobucket.com/albums/y116/skrim/newlens.jpg
Crissa
Justiss
Aug 16, 2009 09:44 as a reply to  @ Skrim17's post |  #7
I did shoot in raw, but the computer I'm on won't accept the CR2 files so I've saved them onto DH's computer.
ISO on the second shot was 400.
I think the noise is what is bothering me the most. The second shot is really noisy and there's no detail in the face. I think I expecting every photo to look as sharp as what Yaamon posted...
The top two were in the evening, so maybe it was my lighting...
Thanks for your comments!
And Skrim17, I love your edit! :D
Kathryn
JohnJ80
Aug 16, 2009 10:25 |  #8
The noise has nothing to do with the lens. That means that you underexposed. In general, if you slightly overexpose images in digital and then bring them back in post, you get much better noise performance. See:
http://www.luminous-landscape.com/tutorial​s/expose-right.shtml (external link)
In your second shot, you needed to either slightly overexpose the background or add some fill in flash. In the first case you do this by dialing in some exposure compensation. In the second case, set the exposure for the background to be exposed properly and then set the flash to fire. The EOS flash circuitry will properly expose the foreground (subject) thereby bringing up the girl to be properly exposed (not in shadow) and strongly, if not completely eliminate, the noise.
Makes sense?
That said, I think your images are great. The reproduction of color is superb, the contrast is just about perfect to my eye, and it is sharp like one would expect from a great piece of L glass like you have. Canon does recommend that some modest sharpening be applied. The don't do it in camera (unless you dial it in - not recommended) so as not to destroy detail. There is a Canon white paper around somewhere that details recommended sharpening settings on Canon EOS DSLRs but I can't find it at the moment. I think it is something like 300/?/0.25 or something like that.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
Justiss
Aug 16, 2009 10:39 |  #9
Thanks JohnJ - I learned a lot from this trip to beach, and I think your comments on the exposure are correct.
So much to learn! :D
Kathryn
1,559 views & 0 likes for this thread, 7 members have posted to it.
878 guests, 133 members online
