Thread started 17 Aug 2009 (Monday) 05:48
Pocket Wizard TTL
Borderfox
Aug 17, 2009 05:48 |  #1
Just about to push the button on purchasing these but in which order to get them, I want two off camera flashes and the transmitter on the camera. Do I get two Mini TTL units and one Flex Transceiver or the other way around? descriptions are a bit confusing..
Click Here and Join the POTN flickr Group Today! (external link)
Hermes
Aug 17, 2009 06:10 |  #2
The Mini is Transmiter only. The Flex is a receiver and transmitter. Any off-camera flashes will need a Flex. The only real decision you have to make is whether to use a mini or a flex on-camera. I personally use Flex's for everything as they take AA batteries and the price difference is so small.
Borderfox
Aug 17, 2009 06:13 |  #3
Hermes wrote in post #8472950 (external link)
Thanks for the quick answer, if the flex takes AA I would be nearly better off using them and no minis.
rjc1
Aug 17, 2009 12:02 |  #4
Take a look at the profile of each, there was a thread with pics of each on a camera(do a search). The mini is much smaller, sits on top of camera much nicer. Plus you will always need a transmitter on camera.
40D with 28-135 IS , Tamron 17-50 ,100-400 f4.5-5.6L, 100mm f2.8L macro IS, 430EX, 430EXll,MiniTT1/FlexTT​5 , Kata R-103,
Domke F2 shooters bag
Hermes
Aug 17, 2009 12:18 |  #5
It's smaller but they're both the same height and both weigh very little. I'd planned to use the mini on camera until I actually tried the flex and found that the size really made no difference to me.
If the mini was substantially cheaper then it might be worth it but an extra £20 in the UK to get a transmitter and receiver over a transmitter alone just seems like much better value. PW tend to make everything backwards-compatible so in a few years time when their next model is out, the flexs will no-doubt still integrate as triggers for studio strobes and speedlites whereas the mini will be obsolete or at least superseded.
1,360 views & 0 likes for this thread, 3 members have posted to it.
Pocket Wizard TTL
894 guests, 133 members online
