Thread started 18 Aug 2009 (Tuesday) 06:35
Prep me for my first headshot
imahawki
Aug 18, 2009 06:35 |  #1
I've got some stuff arriving this week which of course I don't know how to use. So that my first experience with studio strobes isn't abject failure can you guys give me the photography 101 lowdown on setting up a two light headshot?
Here's what I have: Canon XSi, Benro Tripod, two Calumet Genesis 200 en route, a Sekonic 308 light meter, and Cactus V4s to fire everything. For the time being, I'm going to be using my gray home theater projector screen as a background for my headshots (this is all academic, no "clients" at this point).
Should I setup one light at the typical 45/45 for main and the other behind the camera for fill? Or put the fill light on the opposite side at 90 degrees from the model for side fill?
Like I said, what's kind of the first light setup a budding photographer would learn before running off and experimenting?
Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
My Zenfolio Gallery (external link)
bobbyz
Aug 18, 2009 08:50 |  #2
Stickies at the top
https://photography-on-the.net/forum/showthre​ad.php?t=138912
Fuji XT-1, 18-55mm
sdipirro
Aug 18, 2009 08:52 |  #3
Any modifiers for these lights? I'd start by playing around with just one light, positioned at 45 and use the meter to get the exposures right. Then introduce the fill light and try a few different positions with it and use a 2:1 main:fill ratio to start, noting the exposures and shadows.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
imahawki
Aug 18, 2009 09:45 |  #4
Thank you for the resources. I have not read through all of that.
sdipirro wrote in post #8479851 (external link)
The lights come with 45" white umbrellas that can also be shoot through umbrellas.
For ratios the 2:1 is f-stops right? So if I'm at f/11 on the main, I'd want to be at f/16 on the fill? If I'm at f/16 on the main, I'd want to be at f/22 on the fill. Correct?
Hermes
Aug 18, 2009 10:03 |  #5
You've got the ratio wrong and the lights backwards.
For a 2:1 ratio, the key and the fill should be equal.
imahawki
Aug 18, 2009 10:05 |  #6
Key and main are synonymous right?
For a 2:1 that doesn't mean that one should be 2x brighter than the other?
Hermes
Aug 18, 2009 10:09 |  #7
imahawki wrote in post #8480322 (external link)
It's a 2:1 ratio as the areas of the face being lit by the key & fill combined (for example - f/8 + f/8 = f/11) will be 1 stop brighter than the shadow areas which are being lit by the fill alone (f/8 ) You'd set your camera aperture to the combined reading (f/11 in this case).
imahawki
Aug 18, 2009 10:37 |  #8
So from a procedural perspective would I:
1) turn on the main light, take a reading on the highlight side
2) turn off the main light, turn on the fill light, take a reading on the shadow side
3) adjust either the main/fill or both to get the desired ratio
4) turn both lights on, take a reading to get my camera setting, and then fire away?
TMR ­ Design
Joined Feb 2006
Aug 18, 2009 11:23 as a reply to  @ imahawki's post |  #9
If the main and fill are correctly placed for a head shot and metered at f/8 then as Hermes has said, the highlight side of the face is receiving 1 part of light from the main light light and 1 part of light from the fill. The shadow side of the face is receiving only 1 part of light from the fill.
That represents a 2:1 ratio with the fill at 1 stop less than the main.
Robert
bobbyz
Aug 18, 2009 11:34 |  #10
This thread over the Monte Zucker forum will show things with pictures.
http://forum.montezuck​er.com/index.php?act=S​T&f=11&t=8344& (external link)
Fuji XT-1, 18-55mm
TMR ­ Design
Joined Feb 2006
Aug 18, 2009 11:39 as a reply to  @ bobbyz's post |  #11
I always liked Monte and that's a good thread. I'm not sure it's the best for someone that is looking to be 'prepped' for their first head shot session but the information and images are a great learning resource.
Robert
imahawki
Aug 18, 2009 12:16 |  #12
TMR Design wrote in post #8480723 (external link)
OK, NOW I've got it, I wasn't picking that up the first time. Thank you.
Hermes
Aug 18, 2009 12:29 |  #13
Keep in mind that these are just starting points and you'll ultimately want to do things according to your own tastes. I don't think I've ever used a 2:1 ratio in a real shoot as the heavy fill light just seems washy and artificial with no character or definition to me, at the same time there are probably photographers out there who never use anything else.
TMR ­ Design
Joined Feb 2006
Aug 18, 2009 12:35 as a reply to  @ Hermes's post |  #14
Agreed Hermes. Even though it's still somewhat generic, a more common setup and ratio would be 3:1.
I know it can be confusing but in a 3:1 ratio you've got your fill at let's say f/5.6, delivering 1 part of light to each side of the face. The main light is metered at 1 stop over the fill (f/8 ) and is therefore showing 2 parts of light on the highlight side of the face. Those 2 parts plus the 1 part from the fill gives you 3 parts of light on the highlight side and 1 part on the shadow side, thus making it a 3:1. This creates more contrast and makes for a much more interesting image. If you were to increase the contrast between highlight and shadow you can create some drama and some really nice effects. Many photographers will go as far as 4:1 or 5:1 for high contrast and drama.
Robert
imahawki
Aug 18, 2009 12:37 |  #15
See, now I'm getting it. And yes, I understand its a matter of style/taste. I just wanted a starting point.
2,422 views & 0 likes for this thread, 8 members have posted to it.
Latest registered member is RawBytes
1399 guests, 159 members online
