Thread started 18 Aug 2009 (Tuesday) 10:40
Is this sensor dust?
hoanglong
Aug 18, 2009 10:40 |  #1
well i've never seen dust this big... and when i looked at the sensor its reflect like a smudge on the lens
if is a dust, and its that big it would have been easily blown away with a rocket blower. i tried blowing it for 5 minutes and no luck... should i try to clean it with SensorKlear or send it back to canon? anybody have dust this big before?
thanks in advance
bckane
Aug 18, 2009 10:43 |  #2
never seen althing that big......can you see it with mirror lock.?
Brian
Canon 7D-40D gripped | EF 24-105mmL | EF 100mm | EF 28-135mm | EF 70-200 F/4L | EF 135 F/2L | Sigma 17-70mm | EF 50mm 1.8 | Tokina 11-16mm | Speedlite 430EX
| Bogen 3265 | Manfrotto 055xprob and Manfrotto 488RC2 | Katz Eye Optics | Sigma 70-200mm F2.8 EX DG | ZERO Balance check book |
bckane
Aug 18, 2009 10:44 |  #3
might be the loch ness mostor
Brian
ironchef31
Aug 18, 2009 10:55 |  #4
I check sensor dust with Notepad maximized on my computer.
Open notepad and maximize it so you have a big blank white monitor.
Set your camera to f16, shutter speed to about 1sec and manual focus.
De-focus the camera and take a picture of the blank white monitor while panning around the white monitor. Have a look at the photo and it will reveal any dust spots present.
Maybe it's the start of a black hole caused by the Hadron collider
Ken
30D, 18-55mm, nifty 50, 17-55 F2.8 IS, 70-200 F2.8 IS
I tried to bounce my flash off the ceiling once. Left a mark on the ceiling and broke my flash.
CJinAustin
Aug 18, 2009 12:07 |  #5
Some stuff just doesn't blow off and has to be wet cleaned.
- GEAR -
Canon 1Ds Mark V | Canon 5D Mark IV | Canon 7D Mark II
50 1.0L IS| 85 1.0L IS | EF 10-1000L f/1.0 IS DO USM | 17-4000L IS | 24-7000L IS | 70-2000L 2.8 IS | Canon G12 | 580EXIII | 430EXIII
Roljerj
Aug 18, 2009 15:26 as a reply to  @ CJinAustin's post |  #6
Set your camera to manual sensor clean, then take a small flashlight and shine it on the sensor. If there is a dust bunny that big in there you should be able to see it even without magnification.
If it is stuck on there than bad then as mentioned wet cleaning would be a good option. A Sensor Klear pen would probably clean that off too. This is just part of the fun of digital, sensors need to be cleaned periodically.
5DII, 7D, EF 50 1.4, EF 85 1.8, 100L Macro, 135L[COLOR=black], 400L 5.6, 17-40L, 24-105L, 70-300L, 15-85 IS
Rayk
Gallery: 271 photos
Aug 18, 2009 17:18 as a reply to  @ Roljerj's post |  #7
It`s dust.
Regards Ray
LRPS - Licentiateship of The Royal Photographic Society- CPAGB - HON CPE - ACA - Adobe Certified Associate
www.rakphotographic.co​m (external link)
Follow me on Facebook (external link)
POTN ­ Head
"proof that I have no life"
Aug 18, 2009 17:50 |  #8
bckane wrote in post #8480516 (external link)
IMAGE: http://smileys.on-my-web.com/repository/Animals/yeti-002.gif
or a yeti?
Jon- 5D
Invertalon
Aug 18, 2009 17:54 as a reply to  @ Rayk's post |  #9
I had a few spots like that, although not as big the last few weeks... Checked the dust issue at f32 shot at the sky, along with f22 and f11... I must of had 20-30 dust speckles, although I may of only saw one, maybe two on certain shots. I went and bought the Copper Hill cleaning kit, which had the wet cleaning kit, the blower, and sensor sweep for like $50. I did the wet cleaning and blew it with the air afterwards. I now maybe see 3-4 speckles (more stubborn dust) which will probably come off in the future. But it removed roughly 75% of the dust I did see.
Great kit... Plus, they even threw in a rainbow slinky and M&M's in my order bw!
-Steve
canonloader
Gallery: 6 photos
Aug 18, 2009 17:56 |  #10
That is not a big piece of sensor dust. I've had bigger. It is sensor dust though. The longer you go between wet cleans, the more crud residue you get sticking to the sensor filter. It's in the air, all the time, everywhere. Humidity, oils, sneezer snot floating around in the air, it might have even come from something growing inside the bulb of your blower. Anyway, after awhile, it sticks and you need a wet clean or two. I use Copperhill.
Mitch- ____...^.^...____
BLACK ­ MAMBA
Aug 18, 2009 19:55 as a reply to  @ canonloader's post |  #11
+1 lochness monster
bw!
S I G N A T U R E
dgoakill
Aug 18, 2009 20:02 as a reply to  @ BLACK MAMBA's post |  #12
any other shots that it appears on? that was at f8. mine had serious dust and oil from the mirror motor thingy but was not visible until f16 or higher. could be dust in the air not on your sensor in front of the camera as you clicked the shutter. use the notepad trick as mentioned above or just full size a white base layer in photoshop. to shoot against before you poke the sensor.
Gear: Camera & Computer
Portfolio (external link) | Blog (external link) |
Instagram (external link)flickr (external link)
Lazuka
Aug 18, 2009 20:03 |  #13
POTN Head wrote in post #8482855 (external link)
[GIFS ARE NOT RENDERED IN QUOTES]
or a yeti?
lol my vote is on yeti.
I suck at Photoshop.
Lyndön
Aug 18, 2009 20:38 |  #14
You guys are complicated with the "notebook pc photoshop white layer dust detection process". Just put it in Av or M, switch lens to MF, crank the aperture to a large #, and shoot something blank (copy paper, wall, whatever you can find) no PC necessary. I use the light tan wall in my dining room or whatever I can find if I'm not at home. As long as it's a solid light color, you're good.
Another vote for copperhill here. Works great and easy to do. That reminds me, it's probably about time to clean it again... since I've been doing a lot of hiking with the camera lately :cool: .
Todd ­ Lambert
I don't like titles
Aug 18, 2009 20:41 |  #15
I don't see anything. [Shrugs] ;-)a
2,333 views & 0 likes for this thread, 14 members have posted to it.
1626 guests, 172 members online
