Thread started 18 Aug 2009 (Tuesday) 19:14
Some Help Please
melindac
Aug 18, 2009 19:14 |  #1
Hi,
What do you think of the before and after picture. Does the PP and HDR do anything for you? Also, I can still see a faint line where the power line used to be. Any suggestions on how to get rid of that?
Thanks in advance!
IMAGE: http://lh3.ggpht.com/_z5C-Yc-BZ5Y/SotClQHiCrI/AAAAAAAAAX0/ph1qCxd1Gig/s800/IMG_4182.JPG
IMAGE LINK: http://picasaweb.googl​e.com …1BvhXuA?feat=em​bedwebsite  (external link)
IMAGE: http://lh6.ggpht.com/_z5C-Yc-BZ5Y/SotC6Bm2gwI/AAAAAAAAAX4/OJHLNMZAcAY/s800/church_a.jpg
IMAGE LINK: http://picasaweb.googl​e.com …n9ZMnRw?feat=em​bedwebsite  (external link)
dawnkyung
Aug 18, 2009 19:55 |  #2
My first thought when looking at the "After" picture was WHOA!
I like the building a lot, but the streetlights kinda throw me off.
Did you clone out the wire? Try to heal brush it some? Maybe take a brush with the same color of the area with a soft edge on multiply and go over the edge some?
dawn | 29 | gear
gcflora
"I'm not normal"
Aug 18, 2009 20:50 |  #3
I'm not sure. I think that if the first one was lightened a bit and the wire cloned out that I'd like it (the first one) better. By the way, the cloning out of the wire in the second photo is a bit... obvious :)
Cheers,
Craig
http://www.australimag​e.com.au (external link)
Robert_Lay
Aug 18, 2009 21:07 |  #4
I think you did a great job. While you were at it, it would have helped to straighten out the horizon and correct the converging verticals.
For future reference, I suggest taking such a shot a little later in the evening. The balance between the artificial lights and the twilight is critical.
The composition might be just a bit better with more foreground and less sky - plus it would have reduced the converging verticals to get the camera closer to level.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
rw2
Aug 18, 2009 21:55 |  #5
Just for fun. Pushed the limits. You can also use the blurr tool to help with the remaining line left by the wire.
If you're afraid of failure ... you'll never succeed!
Rob
melindac
Aug 18, 2009 22:14 as a reply to  @ Robert_Lay's post |  #6
Thank you all for your comments and suggestions.
dawnkyung - I will try your suggestion with the PP.
gcflora - I agree, the line is definitely obvious.
Bob - Luckily the church is nearby so I'll try out your suggestions. What tool in photoshop do you recommend to fix the converging verticals? Transform?
rw2 - I like your edit. It looks cool and I definitely don't see the line there anymore.
kylejackson
Aug 18, 2009 23:06 |  #7
i like the first one, don't like the hdr at all
kjonnnn
Aug 19, 2009 01:48 |  #8
Hmmm. Just a personal choice when it comes to HDR ... I prefer a photography to look like a photography and art to look art ... Even the most extreme HDR "can" look beautiful, but he can easily be used as a crutch for just bad photography.
Anyway. With this photo, other than HDR, I think the key to post processing is in using various selection tools to edit parts of it separately. I selected the ground and sky separately and adjusted levels and saturation separately. Also used a slight surface blur on the church, and a bit of sponge saturation on just the lights. I used the clone and patch tools to get rid of the electrical wires. If you gonna get rid of the wires, you might as well get rid of the traffic lights too.
The top of the trees could be done better, but hey, I'm sleepy. LOL
Robert_Lay
Aug 19, 2009 23:05 |  #9
melindac wrote in post #8484065 (external link)
I believe it is called "Transform Perspective", and you use the Crop tool and check the "Perspective" option.
Bob
melindac
Aug 21, 2009 22:06 |  #10
kjonnn - nice PP. i like how you removed the traffic lights. i was too tired to remove it after cloning out the lines. maybe i'm doing it wrong. do you use a big or small brush.
kjonnnn
Aug 21, 2009 22:17 as a reply to  @ melindac's post |  #11
Thanks. The size brush I used was a little bit smaller than the with of the light pole.
1,588 views & 0 likes for this thread, 7 members have posted to it.
Some Help Please
2693 guests, 136 members online
