Thread started 19 Aug 2009 (Wednesday) 07:56
Hulk and SheHulk getting Married?
ryannbaker
Aug 19, 2009 07:56 |  #1
My camera has done this before, but only once so I didn't think much of it. But this past wedding I did it happened 5 times. So I need to know what I'm doing wrong or if my camera is dying a slow painful death.
I have a Canon 20D, I've owned it since Feb/Mar of 2004 and have used it like an amateur - more than a hobbyist, less than a pro. It has been dropped once and it jacked with the hot shoe - the flash no longer makes a clean connection, I have to hold it in the right place for it to work (I say this because this might be the source of the problem).
Despite the fact that this is flat-out a bad picture (not looking for a critique on it), why is it green? Any thoughts? Is the sensor failing or something? Or is the bad connection to the flash (580EX II) some how messing with the picture? (The more I look at this picture, the more I almost don't want to put it up just because its so bad).
Oh, and no, I didn't change the settings to make it green (Its not on B/W with a green tint). This should be a standard color photo that is a bit more vibrant and sharp.
HTTP response: 404 | MIME changed to 'image/png' | Byte size: ZERO
Sorry if this is in the wrong forum, wasn't sure. Feel free to move it if necessary.
ryanbaker
Crimson Media
stathunter
"I am no one really"
Aug 19, 2009 08:01 |  #2
Interesting - I am guessing that your camera indeed is dying. Sad to see - I still have a 20D that I only take out for special occasions where I want a smaller body - it still produces fantastic images - hate to think this could happen.
I would contact Canon CPS and see what they think.
Scott
"Do or do not, there is no try"
jmborkowski
Aug 19, 2009 08:26 |  #3
What was your white balance set to?
jimlp
Joined Sep 2004
Aug 19, 2009 10:08 |  #4
ryannbaker wrote in post #8485944 (external link)
Why are you using a camera with a bad flash connection for weddings? Yea it looks like the camera may be on the way out.
Canon 1DsMk2, EOS RP, Canon 17-40 f4L, 24-105 f4.0L ll, Canon 70-300 f5.6L IS , Sigma 85mm f1.4
Tixeon
Joined Oct 2004
Aug 19, 2009 11:27 |  #5
This image can be saved (improved) quite a bit. If you turn on image editing ok, I will post a corrected version unless someone else beats me to it...............tw
Tim
______
Any cat owner will tell you -- no one really owns a cat...
carshop
Aug 19, 2009 15:12 |  #6
How do you allow image editing?
ShawnSmugmug (external link)/Flickr (external link)/LikeMyFacebook (external link)
Canon 70D Gripped|
Canon 70-200 2.8 IS|Canon 24-105|Canon 18-135
Canon 580 EX II|Sigma 18-50 2.8
Canon 55-250|Sigma 17-35 2.8| 2 Pocket Wizard II
Vulcan58
Aug 19, 2009 15:16 |  #7
carshop wrote in post #8488243 (external link)
Go to your user profile and check the box.
carshop
Aug 19, 2009 15:17 |  #8
Its ok
Found it
Canon 70D Gripped|
carshop
Aug 19, 2009 15:17 |  #9
Vulcan58 wrote in post #8488268 (external link)
Canon 70D Gripped|
yonders
Aug 19, 2009 15:20 as a reply to  @ carshop's post |  #10
I'm the second guy asking, 'What was the white balance setting on your camera?'
NIKON D700 | NIKKOR AF 80-200 f/2.8D ED | TAMRON SP 28-75mm f/2.8 XR LD Di | NIKON SB 700 | BLACKRAPID RS-4.
hawkeye60
Aug 19, 2009 15:34 |  #11
In Photoshop try a Channel Mixer adjustment layer, and curves adjustment.
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
ryannbaker
Aug 20, 2009 07:59 |  #12
yonders wrote in post #8488291 (external link)
White Balance was set on Flash.
As for making the image look ok, I've got the RAW file, and I can make it the correct colors for the skin and everything, but I was just wanting to know why the image came out green. I might change the image, but there's a fair chance I'm just going to delete it or not give it to them (it sucks, so much wrong with it).
This just happened to more pictures. So I didn't know if that meant my camera was dying, or if its still ok.
ryanbaker
Crimson Media
hawkeye60
Aug 20, 2009 11:29 |  #13
This is a very quick fix using a channel mixer adjustment and a curves adjustment.
Project22a
Aug 20, 2009 23:35 |  #14
Nice save!
B&W film shooter gone digital.
2,376 views & 0 likes for this thread, 10 members have posted to it.
1567 guests, 117 members online
