Thread started 19 Aug 2009 (Wednesday) 22:34
Where are my LR2 custom filename templates?
Kent ­ Clark
Aug 19, 2009 22:34 |  #1
In Martin Evening's LR2 book ( page 52, figure 2.8 ) he shows a picture of the custom file name template available in the import photos dialogue box. There is:
Custom Name (x of y)
Custom Name - Original File Number
Custom Name - Sequence
Custom Name
and others. But when I click on the template drop down box I have nothing but Custom Settings. Where did the list Evening shows go? How do I get them back? This is LR2.4.
René ­ Damkot
Aug 20, 2009 07:52 |  #2
They should be there by default.
Renaming is only available if you copy or move, or import from device, but you know that already.
IMAGE: http://img.skitch.com/20090820-g6mtgq7yxg3fij1axayfg3bidb.jpg
IMAGE: http://img.skitch.com/20090820-kkxwh45ta5j7w4t4trgadge8tw.jpg
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Kent ­ Clark
Aug 20, 2009 10:21 as a reply to  @ René Damkot's post |  #3
Yep Rene, that is exactly what Evening shows and what seems should be there by default. But when I click on that drop down it has "Custom Settings" and "Edit" that's all. Custom settings is check marked but it does nothing and Edit brings up the template editor.
I have updated the original install to version 2.4. I've checked preferences, maybe I'll try resetting everything to default and see what I get.
René ­ Damkot
Aug 20, 2009 11:28 |  #4
Well, you could of course fairly simple create your own using "Edit"...
Kent ­ Clark
Aug 20, 2009 11:39 |  #5
Sure, I can recreate them, but I'm more concerned with why my program is missing something that should be available by default. If I'm missing this I wonder if I'm missing other things as well that I don't know about.
jacuff
Aug 20, 2009 11:44 |  #6
Just do a search for Filename.lrtemplate. Most likely the content is still there, just in a different directory than Lightroom expected it to be. I'm not on a mac, so my files are located under:
"\Users\*USERNAME*\App​Data\Roaming\Adobe\Lig​htroom\Filename Templates\
Gear, Feedback (eBay (external link)), Web (external link), Blog (external link), FB (external link), Twitter (external link)
Kent ­ Clark
Aug 20, 2009 21:13 |  #7
jacuff, I found the filename template folder in C:\Documents and Settings\the clarks\Application Data\Adobe\LIghtroom\F​ilename templates
In that folder are Custom Name, Custom Name - Original File Number, Custom Name - Sequence, Custom Name (xof y), Date - Filename, Filename, and Filename - Sequence, all of the templates that Rene and Martin Evening show. The template file is with the other LR folders like Develop Presets, Export Actions, Filter Presets, etc.
How do I tell if LR is not looking for the files in the right place?
jacuff
Aug 21, 2009 04:05 |  #8
Create a new one and do a search for it. The folder ou find it in will be where Lightroom is looking for them. Then you could just copy all the folders from the old Lightroom to the new Lightroom location.
Kent ­ Clark
Aug 21, 2009 20:44 as a reply to  @ jacuff's post |  #9
jacuff, I created a new template and found it here:
my documents/my pictures/Lightroom/Lig​htroom Settings/Filename Templates
and the only template in there is my new one. This set of LR folder in My Docs appears to have the same folders as the other set.
So, why do I have two sets of LR folders? Which one should I be using? How do I make LR point to the right ones? I haven't found anything about LR program folder structure in googling or reading.
Thanks for your help.
1,766 views & 0 likes for this thread, 3 members have posted to it.
1125 guests, 125 members online
