Thread started 20 Aug 2009 (Thursday) 18:04
Cactus troubleshooting help please?
imahawki
Aug 20, 2009 18:04 |  #1
My Cactus transmitter/receiver combo plus extra receiver arrived today. I can't get the LED on any of the three units to light up. I've replaced the AAAs in the receiver and tried both receivers. The instructions don't even make it clear which position is on for the receiver (red showing or red hidden on the slider). And I can't get the LED to light up at all on the transmitter. I guess before I assume they're defective, I have a couple questions.
1) Will the LED on the receiver light up if it doesn't detect the transmitter, or should it light up when its on, no matter what?
2) What position IS on on the receiver? Red showing, or red covered by the slider?
3) Is there any trick to turning the transmitter on? Do you hold the test button down? Will the transmitter power on when its off the hotshoe or not?
Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
My Zenfolio Gallery (external link)
Kevin ­ Curtis
Aug 20, 2009 18:29 |  #2
1. My transmitter only lights up when i press the test button
2. red should be showing on the receivers when they are powered on
3. the transmitter is on once its connected to the hotshoe
5d Gripped | Canon 24-105L | Nifity 50 f1.8 | Canon 580ex | Ring Flash (external link)
imahawki
Aug 20, 2009 18:40 |  #3
blacklancer wrote in post #8495621 (external link)
OK, none of that's working... but regarding #3, does the transmitter have to be in the hotshoe to fire the receiver? I had assumed you could fire the receiver with the transmitter in your hand, to take reading etc.
Either way, even on the hotshoe I can't get any LEDs at all.
TMR ­ Design
Joined Feb 2006
Aug 20, 2009 18:45 as a reply to  @ imahawki's post |  #4
The Cactus stuff works well for many people but I have heard a lot of reports of units arriving DOA. If you've done the basic troubleshooting and it's not working then more than likely you have one of those dead units and you should probably just contact the seller and get the wheels in motion for getting a replacement asap.
Robert
mufutau55
Aug 20, 2009 18:57 |  #5
Or just get the Yongnuo CTR-301P. I love those over the Cactus now.
Mufutau
TMR Design wrote in post #8495691 (external link)
Kevin ­ Curtis
Aug 20, 2009 18:59 |  #6
theres no batteries on the transmitter. how would you be able to use it to fire the flash if it wasn't on the hotshoe? and why would you want to do that anyway? you can fire it as a test with the button on the transmitter but it has to be on the hotshoe to get power
TMR ­ Design
Joined Feb 2006
Aug 20, 2009 19:00 |  #7
mufutau55 wrote in post #8495746 (external link)
Mufutau
Hi Mufutau,
Are the Yongnuo triggers proving to be better and more reliable than the Cactus?
Robert
imahawki
Aug 20, 2009 19:04 |  #8
I'm out and about now but I bought a new battery and put it in the transmitter and the transmitter and receiver LEDs are now both lighting up when I push the test button now. I'll report back if it fires my strobes later tonight.
mufutau55
Aug 20, 2009 19:06 |  #9
Yes, at least for me.. but then I had the Cactus v2s then even modified with the antenna, I still had some problems like some are still having on the v4
but I have not had any problem on the CTR-301P, and i hope they transfer the new technology (2.4 GHz) of their latest Shutter/Camera Trigger, that may eve solve more frequency problems on all the ebay triggers.
Mufutau
TMR Design wrote in post #8495759 (external link)
Hi Mufutau,
imahawki
Aug 20, 2009 20:33 |  #10
blacklancer wrote in post #8495755 (external link)
Not true, there is a battery in the transmitter and it does not have to be in the hotshoe to fire. The reason you would want to do that is to make your strobes fire so you can use an incidental light meter to set your exposure. Like I said a couple posts back, I replaced the battery in the transmitter (an odd size) and now everything works.
1,343 views & 0 likes for this thread, 4 members have posted to it.
Latest registered member is RawBytes
1412 guests, 161 members online
