Oh boy. Shooting a wedding tomorrow and there is a large window behind the head table. It is south facing and will be 6pm, so plenty of light left.
I have 2 speedlights and stands... Is this the best option?
potn_momma2 Senior Member 350 posts Joined Jul 2008 More info | Aug 21, 2009 18:11 | #1 Oh boy. Shooting a wedding tomorrow and there is a large window behind the head table. It is south facing and will be 6pm, so plenty of light left. https://photography-on-the.net …?p=5960761&postcount=1286
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 21, 2009 19:38 | #2 Your two options are to add light (radio slaved flash) or expose for the subjects. Exposing for the subjects will give you terrible contrast, so adding light is the best option. You may need the speedlights pointed direct, not bounced or diffused. Use the shortest shutter speed your camera can manage - 1/250th or 1/200th depending on your camera. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Aug 22, 2009 09:58 | #3 Thanks for the advice Tim, https://photography-on-the.net …?p=5960761&postcount=1286
form "inadequately equipped" 4,929 posts Likes: 13 Joined Jan 2006 Location: Henderson, NV More info | Aug 22, 2009 10:20 | #4 your max sync speed is 1/200. The likely max sync speed when using triggers will be 1/125 or 1/160. Las Vegas Wedding Photographer: http://www.joeyallenphoto.com
jonwhite Goldmember 1,279 posts Joined Jan 2007 More info | Aug 22, 2009 21:42 | #5 Depending on whats the other side of the window or even how clean the window is it may be better to just meter the people and blow the background rather than light them up ..... but I would probably do a combo of both, some flashed some blown background. Wedding Portfolio Website
Aug 23, 2009 12:15 | #7 It went really well. I set up my light stands and didn't even bother using them. It was still fairly light outside but not complete day light so I just used my 430ex on camera bounced. https://photography-on-the.net …?p=5960761&postcount=1286
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 23, 2009 17:08 | #8 That's not too bad. The light would've given you better contrast and maybe some detail of what's outside, though sometimes that's not what you want to see. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Aug 24, 2009 15:07 | #9 Yes, that may have been better as there was a view of the lake outside. https://photography-on-the.net …?p=5960761&postcount=1286
mariusz Member 52 posts Joined Aug 2009 Location: toronto More info | Aug 24, 2009 16:35 | #10 shoot on higher speed shooter 1/250s or higher if possible use flash bounced if possible and dont go to high on ISO. Toronto wedding photographer - Heaven Meets Earth Photography
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 24, 2009 17:35 | #11 mariusz wrote in post #8516070 shoot on higher speed shooter 1/250s or higher if possible use flash bounced if possible and dont go to high on ISO. ie expose for the background, flash to fill the foreground, like any situation where the background is brighter than the subject. Bounced flash doesn't always have enough power, I often use off camera direct flash in these situations. potn_momma2 wrote in post #8515517 Yes, that may have been better as there was a view of the lake outside. Need to figure this lighting thing out more! Yeah, you really do, it's incredibly simple. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Aug 25, 2009 11:00 | #12 Tim you should come to Canada and teach a seminar. https://photography-on-the.net …?p=5960761&postcount=1286
-g- Horribly disfigured but learning to cope 12,520 posts Likes: 32 Joined Dec 2007 More info | Aug 25, 2009 12:14 | #13 potn_momma2 wrote in post #8520269 Tim you should come to Canada and teach a seminar. Where in Canada are you?
Aug 25, 2009 14:44 | #14 |
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 25, 2009 17:18 | #15 potn_momma2 wrote in post #8520269 Tim you should come to Canada and teach a seminar. I can get the exposure for the background right, you throw in one flash and I'm ok, but fall apart with two. Wish they had school for these things! Thanks, but it wouldn't make sense to travel internationally to teach the basics when any number of people could teach them. Or books. Or just playing around. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is MWCarlsson 908 guests, 179 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
