I have been shooting with someone else's Sigma 12-24 EX for a few days now, and which I could buy if I wanted to.
I have been looking at tests of this lens on FF, and it looks like it is best at its long end. It also seems that you need to stop down to F/8 or F/11 to get reasonable results in the corners. Furthermore, even at F/11 there still is a lot of vignetting.
From my tests so far this all seems to be the case indeed. Best at 24 mm, a lot of vignetting even at F/11, but worst of all the extreme corners. You can see a marked fall-off in sharpness in the last 15 % or so of the corners, especially at the short end. This sharpness fall-off seems to be more or less the same in each corner.
My question is whether this is really normal, or whether this lens may need calibration?
Furthermore, due to the vignetting, there is a lot more noise in the corners than there is in the centre. How do you deal with this?
Thanks in advance for your replies!
Kind regards, Wim
