Thread started 23 Aug 2009 (Sunday) 21:20
580ex ii problem, please help!
dboot
Aug 23, 2009 21:20 |  #1
Recently, my external flash has been acting up.
It does not communicate with my camera, and it does not fire a flash. It will only fire if I cover the wireless sensor
on the front of the flash with my finger. As soon as the sensor is covered, the flash registers itself with the camera
and the little flash symbol in the view finder appears. As soon as it is uncovered, it goes away!, and no flash will fire
Has anyone else had this problem with their flash's?
If so please help! :)
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Aug 24, 2009 03:26 |  #2
Strange! Do you mean the upper (sensor) lens or the lower (multi-device) one?
Guesses:
1. Loose conductor behind lens which makes contact.
2. Finger action moves foot in camera's hotshoe enough to make/break contact. Clean all contacts in both shoe and foot. (Prime suspect)
3. Flash is in an external metering mode and has not reset properly. Reset all custom functions to defaults.
4. Flash requires Canon service - Aaargh!
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
RichSoansPhotos
Aug 24, 2009 04:37 |  #3
CliveyBoy wrote in post #8512466 (external link)
Guesses:
I second that, sounds like dirty contacts to me, because you might be forcing the flash unit, albeit not too much, but enough to make proper contact with the camera
dboot
Aug 24, 2009 17:50 |  #4
You were right!
I always thought it was because I covered the sensor, but when I tried applying pressure by pushing the flash toward the back of the camera,without covering the sensor, it worked! Thanks a lot!
FlashZebra
This space available
Aug 24, 2009 17:58 |  #5
Your hotshoe on camera may be loose.
See this link for info on how to tighten the hotshoe.
Do NOT use the loctite suggested in the link.
Repeat, do NOT use the loctite suggested in the link.
http://www.conraderb.c​om/flashrepair/ (external link)
Enjoy! Lon
dboot
Sep 10, 2009 10:56 |  #6
So I tightened the hot shoe and that fixed the problem. Thanks alot for your help!
1,123 views & 0 likes for this thread, 4 members have posted to it.
1786 guests, 141 members online
