Thread started 24 Aug 2009 (Monday) 10:27
Rear Curtain Synch and Off Camera Flash
scorpio_e
Aug 24, 2009 10:27 |  #1
When you are dragging the shutter do you set the camera to rear curtain synch when using off camera flash. I am using total manual on the flash and camera.
www.steelcityphotograp​hy.com (external link)
Curtis ­ N
Master Flasher
Aug 24, 2009 11:14 |  #2
How are you triggering the off-camera units?
You can't use 2nd curtain with the Canon wireless flash system, or with a PC cord or radio remote system.
The only way I know of to use 2nd curtain off-camera is to use traditional optical slaves to trigger the remote units while a hotshoe-mounted unit is in manual mode.
2nd curtain sync is not always necessary or desirable when dragging the shutter. Tell us more about the scenario you're trying to shoot.
scorpio_e
Aug 24, 2009 11:25 |  #3
I am using cyber synchs to trigger the Sunpak 120J off camera. I have dragged the shutter before and never thought about using a rear curtain synch.
I came up question because I was watching an instructional video and the instructor was using a SB 900 off camera and using rear curtain synch.
Most of the scenarios I drag the shutter is for portraits in low light when I am trying to bring in the ambient.
Thanks Curtis !!!
PacAce
Joined Feb 2003
Aug 24, 2009 11:55 |  #4
Curtis N wrote in post #8514149 (external link)
Just to clarify, the flash mounted in the hotshoe has to be ETTL compatible, too. A non-ETTL flash sitting in the hotshoe won't fire on 2nd curtain sync, either.
...Leo
bobbyz
Aug 24, 2009 12:01 |  #5
If the subject is not moving, why do you want rear sync?
Fuji XT-1, 18-55mm
scorpio_e
Aug 24, 2009 12:33 |  #6
bobbyz wrote in post #8514425 (external link)
Thats what the guy said in the video *L* He used rear curtain. Maybe it is a Nikon CLS thing.... He used a Nikon with the SB900. He really did not say why he was using rear curtain..
Like I said I never used it but when it came from someone who produced a video I thought " Hey maybe I am doing something wrong"
scorpio_e
Aug 24, 2009 12:34 |  #7
PacAce wrote in post #8514397 (external link)
YEP this is total manual so ETTL is not involved.
Thanks !!!
Curtis ­ N
Master Flasher
Aug 24, 2009 13:00 |  #8
What Leo meant, which I neglected to specify, is that only a dedicated flash unit (E-TTL compatible) will do 2nd curtain sync. Your garden variety hotshoe flash such as a Sunpak 383 or Vivitar 285HV won't do 2nd curtain, even if it's on the hotshoe.
scorpio_e
Aug 24, 2009 13:15 |  #9
YEP Got it... I thought I was missing something.
Thanks for everyone input:)
Christina
Aug 24, 2009 13:32 as a reply to  @ scorpio_e's post |  #10
I'm glad you asked this question - I've been meaning to look into this for some time. In one of Scott Kelby's books he has a page called something like "Rear Curtain Rocks - Why You Should Use It." He advocates setting that to be your default all the time.
This may be slightly off topic but while on the subject of rear curtain... if you were using a reflector, would rear curtain negate its effect? I've wondered about this, as if the flash fires at the very end, I would think there wouldn't be enough time to get the light from the flash to bounce off the reflector into the scene.
Christina - Pittsburgh Wedding Photographer (external link)
Syncopated Pictures (external link)
http://christinamontem​urrophotography.com/bl​og/ (external link)
Curtis ­ N
Master Flasher
Aug 24, 2009 14:37 |  #11
MonteMama wrote in post #8514946 (external link)
Light travels at about 186,000 miles per second. You can estimate the distance and do the math if you want.
But the short answer is, as long as you're shooting something on the same planet, the time required for light to reach your target is insignificant.
bobbyz
Aug 24, 2009 14:42 |  #12
Any reason he mentions to use it all the time?
Fuji XT-1, 18-55mm
Curtis ­ N
Master Flasher
Aug 24, 2009 15:26 |  #13
As I recall McNally's reasoning, at relatively fast shutter speeds it won't matter. Canon cameras actually enable 2nd curtain at 1/30 or 1/60 depending on the model. Faster than that, and it will use 1st curtain regardless. I'm not sure about the Nikons.
So having 2nd curtain set all the time means you can quickly adjust shutter speed to capture a moving subject. You won't miss the shot while you fuss with the menu settings.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Aug 24, 2009 15:27 as a reply to  @ bobbyz's post |  #14
Many flash users employ 2nd curtain sync without having much of an idea regarding what it really does, thus when it really makes any kind of difference.
Me, I rather set the flash to high-speed sync than 2nd curtain, since I see more use for the former than the latter.
Anders
Christina
Aug 24, 2009 15:56 |  #15
bobbyz wrote in post #8515337 (external link)
I read it a long time ago - but I believe it had to do with trails falling behind a moving subject instead of in front of them?
16,657 views & 0 likes for this thread, 17 members have posted to it.
2416 guests, 103 members online
