I'm specifically looking at the C-Pl filters
garycoleman Senior Member 450 posts Likes: 12 Joined Aug 2008 Location: California More info | Aug 25, 2009 02:53 | #1 I'm specifically looking at the C-Pl filters Canon 5D MKIII | Canon 60D | 24-70mm f/2.8L II | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
tgara Goldmember 2,336 posts Likes: 8 Joined Sep 2007 Location: Connecticut, USA More info | Aug 25, 2009 06:16 | #2 garycoleman wrote in post #8518712 I'm specifically looking at the C-Pl filters I think their new HD line is a bit better with hardened glass and multicoatings that are more resistant to stains and scratches. EOS 5D Mark III
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 25, 2009 13:23 | #4 The SHMC line is even better than the HD for transmission...HD 99.35% vs. SHMC 99.7% You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
NYPhotog Member 228 posts Joined May 2009 Location: New York, NY More info | Aug 25, 2009 17:08 | #5 Wilt wrote in post #8521043 The SHMC line is even better than the HD for transmission...HD 99.35% vs. SHMC 99.7% In the case of 'for digital', the older products (not specific 'for digital') are better! The HD 'improvement' is only in the cleaning (less tendency to streak while cleaning) and in scratch resistant coatings--which should not matter if you take care of your filters. I can't recall the last time I had to clean a filter, I don't put nose prints or my grubby fingers on them, and I try to back up before toddler grandkids get to them! So I prefer better optical qualities, not cleaning qualities or antscratch. I have used both and disagree. The difference in light transmission is marginal. The coatings on the HD are far better. Not only is the HD easier to clean, but it also seems to repel dirt, and the HD glass is also much harder than other Hoya filters. The HD uses a thinner mount than the Pro 1, 5mm vs. 5.4mm, lessening vignetting. Optically, the HD is more uniform than other Hoya filters I have used and flare is better controlled. Lastly I find the lubricants used in the HD CPL to be excellent, even in freezing conditions. The filter will not bind, as will some of the B+W CPL filters under similar conditions.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 25, 2009 17:37 | #6 NYPhotog wrote in post #8522186 I have used both and disagree. The difference in light transmission is marginal. The coatings on the HD are far better. Not only is the HD easier to clean, but it also seems to repel dirt, and the HD glass is also much harder than other Hoya filters. The HD uses a thinner mount than the Pro 1, 5mm vs. 5.4mm, lessening vignetting. Optically, the HD is more uniform than other Hoya filters I have used and flare is better controlled. Lastly I find the lubricants used in the HD CPL to be excellent, even in freezing conditions. The filter will not bind, as will some of the B+W CPL filters under similar conditions. Yes, since it generally takes about 3% to visualize a difference (not merely per instrumentation which is far more sensivitive than the eye and brain), I will not dispute the statement. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
NYPhotog Member 228 posts Joined May 2009 Location: New York, NY More info | Aug 25, 2009 18:33 | #7 Hoya is not calling the HD a "for digital" filter". Over the years I have used or am still using B+W, Hoya, Heliopan, Tiffen, Nikon, Schneider, Lee, and Singh-Ray filters (and probably a couple of others that I have forgotten), and I think the HD filters are excellent. I do wish the mounts were brass but, other than that, they are absolutely first rate. BTW, I consider HD (and B+W) filters better than Heliopan, which I think are over-rated and over-priced.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 25, 2009 22:09 | #8 NYPhotog wrote in post #8522620 Hoya is not calling the HD a "for digital" filter". Over the years I have used or am still using B+W, Hoya, Heliopan, Tiffen, Nikon, Schneider, Lee, and Singh-Ray filters (and probably a couple of others that I have forgotten), and I think the HD filters are excellent. I do wish the mounts were brass but, other than that, they are absolutely first rate. BTW, I consider HD (and B+W) filters better than Heliopan, which I think are over-rated and over-priced. Oh, the big 'Digital' on the box must refer to the fact that you hold it in your fingers to screw it on the lens. Photo credit: Ken Rockwell You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Aug 25, 2009 22:11 | #9 Wilt wrote in post #8523609 Oh, the big 'Digital' on the box must refer to the fact that you hold it in your fingers to screw it on the lens. ![]() ![]() Photo credit: Ken Rockwell
NYPhotog Member 228 posts Joined May 2009 Location: New York, NY More info | Aug 26, 2009 00:02 | #10 Great, the box says digital. The fact is you have not given any reasons at all as to why the SHMC series is better than the HD series, other than to provide an inconsequential, meaningless, light transmission measurement. I have listed several improvements of the HD and I would like to hear why the SHMC is superior.
mikechong Member 125 posts Joined Jul 2005 Location: Sydney, Australia More info | Aug 26, 2009 00:23 | #11 If I didn't already have a Circ-Polarizer, I'd definitely get the Hoya HD polarizer simply because the polarizing film used on these block significantly less light than most other polarizers, so you can get faster shutter speeds.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 26, 2009 07:55 | #12 NYPhotog wrote in post #8524110 Great, the box says digital. The fact is you have not given any reasons at all as to why the SHMC series is better than the HD series, other than to provide an inconsequential, meaningless, light transmission measurement. I have listed several improvements of the HD and I would like to hear why the SHMC is superior. Optical performance simply is needed for something going over the front of your lens, plain and simple. The rest (harder to scratch, easier to clean) are frills to address past complaints by some users, or (black edged filter and the other features 'for digital') are marketing hype. I have to read more about the polarizing element in the HD, to see just how much benefit there is, if it is sufficient to net 1/3EV or more, any less is simply hype with no material effect on exposure values. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
NYPhotog Member 228 posts Joined May 2009 Location: New York, NY More info | Aug 26, 2009 13:27 | #13 Wilt wrote in post #8525301 Optical performance simply is needed for something going over the front of your lens, plain and simple. The rest (harder to scratch, easier to clean) are frills to address past complaints by some users, or (black edged filter and the other features 'for digital') are marketing hype. I have to read more about the polarizing element in the HD, to see just how much benefit there is, if it is sufficient to net 1/3EV or more, any less is simply hype with no material effect on exposure values. Well, you made a statement that the SHMC filters were better. I would like to know why they are better. I provided user experience that the HD filters are superior to other Hoya filters. Again, optically they are better, the coatings are better, and the lubricants in the CPL filters are better.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 26, 2009 13:32 | #14 NYPhotog wrote in post #8526998 Well, you made a statement that the SHMC filters were better. I would like to know why they are better. I provided user experience that the HD filters are superior to other Hoya filters. Again, optically they are better, the coatings are better, and the lubricants in the CPL filters are better. SHMC = 99.7% transmission, HD = 99.35% transmission, per Hoya. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
NYPhotog Member 228 posts Joined May 2009 Location: New York, NY More info | Aug 26, 2009 13:45 | #15 Wilt wrote in post #8527028 SHMC = 99.7% transmission, HD = 99.35% transmission, per Hoya. 0.35% difference per their claim, I accept as 'better'. Your reports of 'better user experience' are not optical advantages, are they? HD "optically they are better"...can you elaborate in what way they are better? I'm curious, not challenging! That's it, marginal, light transmission difference, which we have agreed is meaningless? After having used both the HD and other Hoya filters, I have already elaborated as to why the HD series is superior.
| Latest registered member is zachary24 1445 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
