Hi all,
Wondering how many of you edit the proofs you send to customers to choose from, and how much?
potn_momma2 Senior Member 350 posts Joined Jul 2008 More info | Aug 25, 2009 11:33 | #1 Hi all, https://photography-on-the.net …?p=5960761&postcount=1286
Aug 25, 2009 11:54 | #2 I will generally let Adobe Camera Raw auto correct all the files. If there are any color treatments I want to do I will apply them globally to all the files using the synchronize function in ACR. I don't bother with fixing blemishes or anything that requires detailed work on any one image. From there I export a PDF contact sheet of all the images and wait for them to send me the ones they want. It takes no more than 15 minutes to batch and export 400 files like this. Teddy Smith, SOC
Aug 25, 2009 14:46 | #3 Ah perfect! https://photography-on-the.net …?p=5960761&postcount=1286
RDKirk Adorama says I'm "packed." More info | Aug 25, 2009 17:55 | #4 potn_momma2 wrote in post #8520467 Hi all, Wondering how many of you edit the proofs you send to customers to choose from, and how much? Depends on what you're ultimately selling. I have found that it's best never to present the client with an unhappy moment during the preview. Every image should be a pleasure, no image should require any explanations ("I'll fix that later") or self-recriminations from the client. If I know I will Liquify a bit of the flab on a client's arm in the final, I will do that in the preview. TANSTAAFL--The Only Unbreakable Rule in Photography
hkhorn10 Member 120 posts Joined Jul 2009 More info | Aug 25, 2009 23:18 | #5 RDKirk wrote in post #8522468 Depends on what you're ultimately selling. I have found that it's best never to present the client with an unhappy moment during the preview. Every image should be a pleasure, no image should require any explanations ("I'll fix that later") or self-recriminations from the client. If I know I will Liquify a bit of the flab on a client's arm in the final, I will do that in the preview. Generally, I remove any fault that will be visible in the format that I present the previews. "See no evil." However, I also ruthlessly cull my images down to a small selection of the very best. I don't show three images that vary only a little. I'll normally show only the best shot of a particular pose--my artistic eye is part of what they're paying me for. I don't show anything I wouldn't want them to choose.
50D&Grip | 28-70L F2.8 | 50 F1.8 | 85L F1.2 II| 70-200L F4 IS | 135L F2| SL 430EXII |Photoblog
Moppie Moderator 15,098 posts Gallery: 22 photos Best ofs: 1 Likes: 444 Joined Sep 2004 Location: Akarana, Aotearoa. (Kiwiland) More info | Aug 26, 2009 06:44 | #6 hkhorn10 wrote in post #8523928 Instead of allowing them to get lost in 120 proofs from the session online and selecting a few, I present them with the 15 to 20 that are fully edited and in final format. If they're not satisfied, I allow them to access the full DB of raw images to select others. However, in two years, I've never had this happen. In fact, I've noticed something curious. The less images I present them with (20 as opposed to 120), the happier the client seems to be. And further, the more they buy. It seems like having all the proofs to sort through actually causes it's own version of indecision and lack of commitment to the purchasing. If I were still putting up hundreds of images, I wouldn't be editing them all. But in my current system, I do.
flickr
Aug 26, 2009 11:06 | #7 The problem is it's all theory. With selling photos, I don't see an easy way to do a controlled test. One photographer saying he is selling more photos now that he offers less may simply be getting higher end clients, may be getting better at his work, or may simply feel he's selling more since he has far more clients now than he did 20 years ago. Teddy Smith, SOC
| Latest registered member is MWCarlsson 908 guests, 179 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
