I am considering buying this lense: Canon EF-S 55-250mm f/4-5.6 IS.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Is it possible to make decent macro pictures with this?
Answers are very appreciated
!Closed123 Senior Member 512 posts Likes: 44 Joined Aug 2009 More info | Aug 25, 2009 14:23 | #1 PermanentlyI am considering buying this lense: Canon EF-S 55-250mm f/4-5.6 IS.
Is it possible to make decent macro pictures with this? Answers are very appreciated !Canon EOS 80D
Kiwikat Goldmember 1,024 posts Likes: 3 Joined Jun 2009 Location: Appleton, WI More info | Aug 25, 2009 14:42 | #2 Decent? Yes. "Would you really want to be the Canon rep responsible for dealing with POTN?" -FlyingPhotog
PKSmith Member 207 posts Joined Jan 2009 Location: Manhattan, Kansas More info | Aug 25, 2009 14:42 | #3 It won't do technically do macro, which is 1:1 reproduction according to most people. However, it will do about 1:3, which is pretty good for a lens like this. | Rebel XSi | EF-s 18-55 f/3.5-5.6 IS | EF 50 f/1.4 | EF 70-200 f/4L | Speedlight 199A |
Aug 25, 2009 15:02 | #4 PermanentlyStanding 1 meter away doesn't really matter for me, if the pictures are really sharp and really close-up. Canon EOS 80D
Kiwikat Goldmember 1,024 posts Likes: 3 Joined Jun 2009 Location: Appleton, WI More info | Aug 25, 2009 15:11 | #5 This is one of the most beautiful pictures I've seen from the 55-250... "Would you really want to be the Canon rep responsible for dealing with POTN?" -FlyingPhotog
CaptainNBritles Mostly Lurking 12 posts Joined Aug 2009 Location: Black Pudding Country, Lancashire More info | Aug 25, 2009 15:13 | #6 Kiwikat wrote in post #8521553 This is one of the most beautiful pictures I've seen from the 55-250... https://photography-on-the.net …?p=8512763&postcount=9101 WOW, thats a stunner! Must try some of that with mine! If you think things can’t get worse, you have no imagination.
gjl711 "spouting off stupid things" 57,724 posts Likes: 4057 Joined Aug 2006 Location: Deep in the heart of Texas More info | Aug 25, 2009 15:17 | #7 RobinSchouten wrote in post #8521502 Standing 1 meter away doesn't really matter for me, if the pictures are really sharp and really close-up.. What's really close up? As was mentioned, you'll get a .31 mag factor which is not quite 1:3. It does great for closeup but not macro. Not sure why, but call me JJ.
LeonidPhotography Senior Member 715 posts Joined Mar 2009 Location: Cupertino, CA More info | Aug 25, 2009 16:18 | #8 shot this with a 28-135. So I am sure with a 250mm you could get much closer for a macro shot...
Canon 6D, Canon 50mm 1.8 STM
Aug 25, 2009 16:23 | #9 Permanentlygjl711 wrote in post #8521589 What's really close up? As was mentioned, you'll get a .31 mag factor which is not quite 1:3. It does great for closeup but not macro. I mean, sharp images with zooming in don't bother me. Does zooming in show the same details as with a macro lens? Canon EOS 80D
Aug 25, 2009 16:37 | #10 Em2 wrote in post #8521924 shot this with a 28-135. So I am sure with a 250mm you could get much closer for a macro shot...
you have a great bug in your system _______________
gjl711 "spouting off stupid things" 57,724 posts Likes: 4057 Joined Aug 2006 Location: Deep in the heart of Texas More info | Aug 25, 2009 16:57 | #11 Em2 wrote in post #8521924 shot this with a 28-135. So I am sure with a 250mm you could get much closer for a macro shot... The focal leangth has nothing to do with the ability to take macro pictures. All it does is govern the working distance, that is the distance from the lens to the subject. The 55-250 and the standard 18-55 kit lens deliver about the same level of magnification, about 1:3. The 28-135 a little less, 1:5. At 1:3 the smallest target you can photograph and fill the frame would be about 2" by 3". To get smaller targets you need a macro lens capable of magnifications of 1:1 or a set of tubes to increase the magnification of the lens. This: (1:1 or a full size pic) Or this (3:1 or there abouts. Bigger than life size) Not sure why, but call me JJ.
Aug 25, 2009 17:10 | #12 Permanently-Well the first one isn't possible with the lens I have at the moment, the 18-55mm. So I guess the 55-250mm could handle the first one easily, that's the start. Canon EOS 80D
blssdwlf Senior Member 543 posts Joined Jun 2007 Location: Houston, TX More info | Aug 25, 2009 17:10 | #13 Thank you gjl711 for illustrating the difference in magnifications Regards,
Aug 25, 2009 17:20 | #14 RobinSchouten, Sony A6400, A6500, Apeman A80, & a bunch of Lenses.............
IShootThings I thought I was special....... 2,032 posts Likes: 26 Joined May 2009 Location: North Cali More info | Aug 25, 2009 17:21 | #15 55-250 plus extension tubes. Canon 5D3, Canon XTI (IR converted), 24-70 f2.8L, 16-35 f4L, 50 1.4, 70-200 f2.8L, 100 2.8 macro, 430 ex & 580 exII speedlights.
| Latest registered member is zachary24 1387 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
