Thread started 25 Aug 2009 (Tuesday) 21:08
Looking for the wiring dia/pin out for the Quantum CZ cable or Canon external battery
Blackey ­ Cole
Aug 25, 2009 21:08 |  #1
I have a Quantum CZ cable and turbo battery, but don't have it handy at the moment. Ever since I saw the release of the Canon cp-e4 battery pack I been thinking of making one my self or just by a knockoff.
But I did an internet search looking for the wiring diagrams for the HV port on the Canon flashes where this CZ connects. I am thinking that the battery packs just put out 12vts from looking at some specs. the connector uses three pins.
Without being able to check it I am thinking that one pin is grounf and anouther is +12vts and the third is -12vts. Is this correct and which pin is what? ALso do you have any wiring diagrams that you can post.
Click Here and Join the POTN flickr Group Today! (external link)
int2str
Aug 26, 2009 15:25 |  #2
I've also been very interested in this.
Though somehow I don't think that the battery cranks out 12V. I'm personally thinking 6V. AA batteries have a "nominal" rating of 1.5V, but rechargeable batteries are running at 1.2V. My point being it would be fairly hard to get a continuous 12V out of 8AAs that are in the CP-E4 for example.
My theory would be that it's running 2x4 AA's in parallel to get the additional power for faster recycling. It would be really nice if somebody with a CP-E4 could confirm and measure the pins.
I've been thinking about getting a 2s3p Li-Ion battery and making a battery.
I'm also looking to get the plugs somewhere and right now the cheapest I can come up with is buying a $30 cable just to cut the plug off... Wish there was an easier way to get the plug.
FlashZebra
This space available
Aug 26, 2009 15:47 |  #3
The CP-4E supplies a high Voltage to the compatible flash units.
It is not just a simple battery holder connecting 8 cells in series for 12 Volts.
I suspect the Voltage is a few hundred Volts. Voltage high enough to feed the power capacitor directly.
If you are expecting to just plug in a sundry 12 Volts to that specialized plug, I think you will be disappointed.
Enjoy! Lon
scotch
Aug 26, 2009 15:49 |  #4
Or it's a voltage-regulated type, with as you say, 8xAA, and then a 7812 or summat keeping the 12v constant.
Ooooor, it's a DC-DC (boost) based circuit, turning 2+v into much, much more
int2str
Aug 26, 2009 16:00 |  #5
FlashZebra wrote in post #8527728 (external link)
The CP-4E supplies a high Voltage to the compatible flash units. It is not just a simple battery holder connecting 8 cells in series for 12 Volts.
Enjoy! Lon
Lon,
You have obviously a lot more experience with this than I would ever have, but are you sure about this? Just seems slightly hard to believe that that's the truth. For that to happen, the CP-E4 would need a pretty sturdy capacitor inside. And running high-voltage over a coiled cable like that may not be advisable.
But obviously I may be totally wrong...
Wilt
Aug 27, 2009 09:42 |  #6
This might or might not be of value. Quantum Turbo with cable for Metz flash (Turbo connector as viewed from pin side)...
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/CZpinouts.jpg
6,978 views & 0 likes for this thread, 5 members have posted to it.
1701 guests, 140 members online
