Thread started 26 Aug 2009 (Wednesday) 13:26
Best fast UWA lens ~$500?
jubu
Aug 26, 2009 13:26 |  #1
I'd really like to purchase an UWA lens that is also very capable at low light for indoor shots, without flash. So far, my research has led me to the Sigma 20mm/f1.8, which is priced at just under $500.
Anyone else have recommendations for a decent wide and fast lens for my XSi? It appears that because I'm looking for something with a high aperture, I'm limited to primes, which I don't mind at all.
Thanks!
Canon EOS 5D Mark II | My Flickr Favorites (external link) | Gear List & Feedback
jasonlitka
Aug 26, 2009 14:14 |  #2
20mm on a Rebel is not UWA. Set your kit lens at 20mm and see if that's the view you want, but I'm guessing it's not.
If you can budge on the price a bit then you can consider the Tokina 11-16mm f/2.8. Otherwise, I'm not aware of any fast lens, prime or zoom, that would be considered UWA on a crop-body that is available at that price level.
Jason Litka | Philadelphia-Area Tech Executive/Consultant (external link)
Gear: iPhone. Yeah... Certainly don't own more than that... Don't tell my wife, ok?
nightcat
Aug 26, 2009 14:32 |  #3
I'm a prime guy, but I have to recommend the Tokina 11-16mm 2.8. That is, IF the 2.8 will do the job for you. This lens is far more than decent. Extremely sharp and built like a tank. I have the XSI and its a good pair.
Cyclop
Aug 26, 2009 14:38 |  #4
You may want to consider the Tokina 11-16 f/2.8 lens. Great lens and very fast, love it.
Unfortunately, a new lens runs roughly $600. Look on the bright side, you get a lens hood included with purchase price.
_aravena
Aug 26, 2009 14:39 |  #5
I got mine used used for...just over $500 I believe. I love it and it is tack sharp at F2.8. Truly an amazing lens and an actually UWA. 20mm is not a UWA Jubu. Might want to be clear on what you're looking for.
IMAGE: http://www.lastshotphotography.com/img/v6/p668221639-4.jpg
Last Shot Photography
DutchOven
Aug 26, 2009 14:54 |  #6
+1 on the Tokina 11-16. It's sharp wide open and its fast enough for low lighting conditions. The distortion isn't as bad as the Sigma 10-20mm that I used to have.
Only thing about this lens is that it's hard to find. It's on a nationwide backorder since the last time i checked.
-Kevin
7D | BG-E7 | Canon 50mm f/1.8 | Sigma 18-50mm f/2.8 DC EX Macro | 430EX II | Tokina 11-16mm f/2.8 | Canon 70-200 f/4.0L
MS-18E
Aug 26, 2009 15:58 as a reply to  @ DutchOven's post |  #7
How does the Tokina 11-16 compare with the Canon 10-22 in terms of image quality on a 1.6 crop body?
I'm afraid the narrow range of the 11-16 makes it a very specific lens to use ... is the Canon any much better in this regard?
DutchOven
Aug 26, 2009 16:02 |  #8
MS-18E wrote in post #8527794 (external link)
I've never owned a Canon 10-22, but judging from pictures from the Lens Sample Archive thread, I believe that the Tokina is right up there with the Canon in terms of image quality.
10-22 VS. 11-16
It's obvious the Canon has the advantage in range, but the Tokina DOES have a constant f/2.8 versus the canon's f/3.5-4.5.
-Kevin
MS-18E
Aug 26, 2009 16:08 as a reply to  @ DutchOven's post |  #9
Range vs. speed ...... if only Canon made their 10-22 a f2.8 Would have been a no brainer. Now I'll have to think more :(
_aravena
Aug 26, 2009 16:11 |  #10
Range? It's a UWA...should only be concern with the wide end. I don't think I've zoomed even 1% of the time I have that lens on.
AlpinweissM
Aug 27, 2009 15:37 as a reply to  @ _aravena's post |  #11
+1 on the Tokina 11-16. It's sharp @ f2.8, AF is pretty fast and accurate, and the build is superb. I also noticed that with the Tokina I usually stay on the wide end, plus my kit lens starts at 18mm so I don't really have a concern with the narrow range on the Tokina
during my research, other than the narrower range than the Canon 10-22, the Tokina is on par in almost every other category if not better than the Canon
Canon EOS 7D Grip'd | 24-70L | 135L | Tokina 11-16
Zeiss Distagon
T* 35/1.4 | Planar T* 50/1.7 | Planar T* 85/1.4 | Nikon Nikkor 105 F/2.5
k.lee
Aug 27, 2009 18:31 |  #12
_aravena wrote in post #8527874 (external link)
I'm on the opposing end of this. I quite often use my 10-22 as a walk-around for parks and whatnot and I do like the range the Canon gives. I can use 10mm for when I want an UWA perspective and quickly change to 22mm if I don't want the UWA feeling. the 11-16 however is quite limited on the normal perspective so it might require bringing an extra lens. Also, 10mm is wider compared to 11mm. It might only be 1mm but at the wide end, it really makes a difference.
It's true though the 11-16 is a lot faster than the 10-22. Even though you can easily handhold the 10-22 at extremely low shutter speeds, it does not do any help if your subject is moving. Those times is when the 11-16 truly outshine the 10-22.
Kelvin
Gear list
My
Blog
external link / Flickrexternal link
caesar2164
Aug 27, 2009 18:37 as a reply to  @ k.lee's post |  #13
i like my tokina 11mm, 12mm, 13mm, 14mm, 15mm, 16mm f/2.8 primes... :lol:
Web Site! (external link) - Gear List!
Like Literature? Visit Literary Laundry (external link)!
_aravena
Aug 27, 2009 19:20 |  #14
k.lee wrote in post #8534924 (external link)
Not really as I've had a 10 and 11 UWA and notice no difference...even when I showed 10, 11, 12, etc. Did notice a difference from 10 to 12 but not 11. Yes, slow shutter speeds but F3.5 is a big difference at F2.8 where' I've had to set it and set the shutter to 1/10.
DutchOven
Aug 27, 2009 19:30 |  #15
Tokina's 11-16mm Angle of view: 104-82°
Canon's 10-22mm Angle of View: 107.5-63.5°
3.5° Doesn't make THAT big of a difference.
Source: B&H
-Kevin
2,706 views & 0 likes for this thread, 13 members have posted to it.
1043 guests, 107 members online
