So you clicked, I did warn you!
If you're like me and a little heavy handed then take note of the following, I know I'm not the first becuase there are a similar stories across the internet
I could have left the grip on untill I made the next upgrade but I wanted to get it done sooner rather than later. I over tightened the grip to a state of not being able to un-do it So with a little brute force I turned the wheel and nothing, a free spin!
ok not funny
€150 a time it's not something you want to do a second time!
Moral of the story DO NOT OVER TIGHTEN YOUR CAMERA GRIP - if you do then see the photos below becuause there is no other way of getting it off. Removal process took about 15 minutes, I did try using a different method of turning the little bolt on the inside but I could not get a grip on it..
New one in the post but for now I can only look at the final result's and look back at our good times together..
Canon BG-E2N R.I.P fella
