Thread started 28 Aug 2009 (Friday) 10:02
vagabond 1 vs 2
enginyr
Aug 28, 2009 10:02 |  #1
anyone know the difference?
LA Wedding photographer (external link) Stunning Bride Photographers.
bobbyz
Aug 28, 2009 11:19 |  #2
Main difference is the grounding rod thing that is required for V1. I would buy V2 for that reason alone.
Fuji XT-1, 18-55mm
enginyr
Aug 28, 2009 11:33 |  #3
what is the grounding rod?
RDKirk
Adorama says I'm "packed."
Joined May 2004
Aug 28, 2009 11:42 as a reply to  @ enginyr's post |  #4
Actually, they should both be grounded for best operation, as should every other doggone such device--Buff is the only one that will tell you about it. Failing to ground could cause problems with some kinds of electronic flash systems that need a true ground connection. It can also cause problems in high static situations, because the flash can't drain static electricity to true ground.
The V2 has a GFCI-equipped outlet that at least won't electrocute you.
RDKirk
Joined May 2004
Aug 28, 2009 11:44 |  #5
enginyr wrote in post #8538783 (external link)
The V1 comes with a wire-connected clip-on grounding rod so that you can either push the rod into dirt or connect it to something like a metal fence pole. The V2 has a connection for a grounding rod, but does not come with the rod itself.
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Aug 28, 2009 12:28 |  #6
I have the V1. The grounding rod is actually a giant bolt you can push/screw into the ground. You attach a cable from the inverters to it via alligator clip. The v1 has two inverters, instead of one and they can be used together or separately. Its a little more clunky than the v2, but for the right price I wouldnt worry about getting the v1.
1,769 views & 0 likes for this thread, 4 members have posted to it.
vagabond 1 vs 2
1026 guests, 119 members online
