Thread started 28 Aug 2009 (Friday) 15:55
Frail Pocket Wizard FlexTT5
Rey
Aug 28, 2009 15:55 |  #1
Be careful with these things. I didn't think the new PW's were too frail until last weekend. I had a 580EXII mounted on the Flex's hot shoe and both were sitting on a bed while I was testing out the settings I just updated the Flex with. As soon as I got the settings straight the units took a tumble onto carpeted floor from about 18" and separated. The 580 took the hot shoe with it. Tiny screws hold the hot shoe in place and I was able to get the hot shoe back on but the Flex no longer triggers the flash from the hot shoe. It's receiving the signal but won't trigger the flash. :(
Totally my fault and I know it's designed like that to prevent a more expensive repair to the flash but from only 18" onto carpeted floor? The tolerance for impacts is just a little bit low IMHO. Now I feel like I have to baby these things.
Called up MAC and they told me it was a $40 fix (+ $15 to return ship) so I sent it in. PITA.
Canon 5D MKII • BG-E6 • Canon EOS-M • Canon 85mm F1.2L II USM • Canon 100mm F2.8L Macro IS USM • Canon 16-35mm F2.8L II USM • Canon 24-70mm F2.8L USM • Canon 70-200mm F2.8L IS USM • Sigma 50mm F1.4 ART • Canon Speedlight 600 EX-RT • Canon Speedlite 580EX II • Canon Speedlite 430EX II • Gitzo 3530 • Really Right Stuff BH-55 LR
ootsk
Joined Jan 2002
Aug 28, 2009 18:55 |  #2
I had a 480 on a flex on a camera tripod, about 4 feet up. On a little mound of grass. While I was shooting with my other light this one tipped over, and hit the only part of concrete in the area. The flash came off of the flex but no damage at all. Slight ding on the 480, and I'm not sure how the 480 got detatched from the flex, but the locking latch was still in the locked position. They both work fine. 4 Days later I was shooting at the same place and I noticed a little door missing from the flash. I went to the area and found the little black piece in the grass.
Guess I got lucky.
GerBee
Aug 28, 2009 19:11 |  #3
Anything on the foot of the will act like a fulcrum and leverage MASSIVE force against it.
Try dropping your flash with the foot that comes with it from about 18" and the chances are the flash dies and the foot is broken.
However, you could otherwise bounce your naked flash off the pavement and the chances are that it would still work fine.
Those Mini & Flex things are a recipe for repeated disasters. Your warning is valid.
Hermes
Aug 28, 2009 19:15 |  #4
I use off-camera cords with all of mine. Pretty clear from using them that with a heavy flashgun perched directly on top of the flex, any moderate impact is going to to tear the flashgun clean off one way or another. I'd rather damage a £12 cord than a £240 receiver.
It's not really any inconvenience. For serious on-camera flash work you'll be using a bracket and therefore an off-camera cord anyway. For off-camera work, sitting the flex on top of a high lightstand screwed tightly to a brass spigot at the bottom and a flashgun at the top is just asking for it to get snapped when the top-heavy stand gets knocked over (and they all do sooner or later). Better to let the oc-e3 hotshoe take the strain and put the flex somewhere lower down where it can be accessed more easily.
Rey
Aug 30, 2009 01:19 |  #5
No doubt that had I had the Flex attached via an off-shoe cord I might have avoided this, but the way PocketWizard designed the Flex bypasses the need for an off-shoe cord. It's obvious that this type of damage could happen but I didn't imagine it could from a mere 18" and onto a soft carpeted floor (which is the main reason I was admittedly a bit careless).
Lesson learned but I wish these things were a bit more sturdy. I hate feeling like I have to baby these things.
GerBee
Aug 30, 2009 05:12 |  #6
Rey wrote in post #8547839 (external link)
The design needs work, IMO it is TOOOO prone to accidental damage from slight altercations. I can see it breaking by just falling over a couple of times.
It reminds my of my first PW PlusII and I was on the forum complaining about the weak foot on those .. almost as poor as the cheap Chinese triggers.
I'm contemplating making a foam case to strap them in, cocoon like, it'll make them somewhat unyielding and will probably need their own box to lug around ~ which might be worth it, as when they work right, they are brilliant ~ four days of frustration with mine though so far
mufutau55
Aug 30, 2009 09:23 as a reply to  @ GerBee's post |  #7
I don't think they are made as strong as the original PWII from the feel of it.
Mufutau
Rey
Sep 05, 2009 16:12 |  #8
Follow up. MAC replaced my unit instead of repairing the existing one. I noticed the packaging has changed as well as the addition of an "authentic" hologram sticker on the bottom. I also noticed that the PocketWizard utility is reporting this as hardware version 107. The older ones were hardware version 100. I wonder what has changed...
Good service and quick turnaround. Hopefully this unit doesn't suffer the same fate as the old one.
k_strecker
Sep 05, 2009 23:15 |  #9
mufutau55 wrote in post #8548885 (external link)
Mufutau
The exact response to this feeling, from Patrick at pocket wizard
was something along the lines of "they have more screws in a smaller device with tighter tolerances than anything else PW has ever made"
But hey, what do they know ;)
mufutau55
Sep 06, 2009 08:27 |  #10
What else do we expect them to say? :)
Mufutau
k_strecker wrote in post #8591746 (external link)
blackshadow
Mr T. from the A team
Sep 06, 2009 08:30 |  #11
I wonder how many have been broken due to 'togs throwing them in frustration because they refuse to work properly.
Black Shadow Photography (external link)
Facebook (external link) Flickr (external link) Twitter (external link)
Gear List Myspace (external link)
jdaly
Nov 04, 2009 22:08 |  #12
I had the same thing happen to my tt5 - I dropped it (doh!) and the hotshoe stayed with the 430exII.
Talk about quick turnaround from MAC. I dropped it off at UPS at 5pm Monday, it was back on my doorstep Wednesday with a replaced hotshoe. Granted it was only going to NY from PA, but still.
John
Rey
Nov 05, 2009 01:27 |  #13
jdaly wrote in post #8957035 (external link)
Did they charge you for the repair/replacement? I was surprised because when I talked to their rep on the phone I was given every indication that I would be charged for it because it was damage I caused, but I wasn't. The replacement came at no charge. Great service, IMO.
jdaly
Nov 05, 2009 11:06 |  #14
Rey wrote in post #8957859 (external link)
Probably a good idea to talk to them directly like you did. I just packaged it up and sent it off fully expecting the fee,which they charged me.
John
Yella ­ Fella
Nov 06, 2009 06:34 |  #15
Interesting... I was planning on upgrading my PWII's to these bad boys... more research needed me thinks :)
Ed - www.edwardlui.co.uk (external link) | modelmayhem (external link) | facebook (external link)
Canon EOS 5D x2 | Canon EF 35mm f1.4 L USM | Canon EF 50mm f1.2 L USM | Canon EF 85mm f1.2 mkII L USM | Canon EF 24-70mm f2.8 L USM | Canon EF 70-200mm f2.8 IS L USM |Canon 580EX mkII x2http://www.edwardlui.c​om (external link)
4,198 views & 0 likes for this thread, 11 members have posted to it.
1390 guests, 123 members online
