Thread started 29 Aug 2009 (Saturday) 10:48
350 IR Issue
MidnightSun
Aug 29, 2009 10:48 |  #1
When taking bulb shots with my 350D recently, the camera won't take anything over 30 sec. with the IR remote. Under 30s, the shot will show OK on the preview screen and everything seems OK. Over 30sec., and the shot won't show on the screen and the #of shots left will flash, even with the camera turned off. The only way to clear the display is to remove the battery. I used to take 5-10 min. exposures this same way, but this just cropped up a couple weeks ago mysteriously. Just wondered if anyone else has run into a similar situation...??
Dave
Canon 350D, AE-1, Orion 8" Newt. f/4.9; EQ6 w/ modified motor drive; Orion 70mm f/10 Refractor Guide Scope; Celestron NexImage CCD Imager; Starshoot Autoguider. Orion Electronic Focusers.
Astro Setup / Midnight Sun Astrophotography (external link)
shutter_imadness
Aug 29, 2009 11:53 |  #2
I'm not sure if the 350D has this option but could it be that you have long exposure noise reduction enabled under your custom settings? It'll take much longer to process the image this way. If you're shooting raw you can just disable this as you can do the noise reduction on your computer.
Canon EOS 30D | EF 50mm f/1.8 II | EF-S 18-55mm IS | polarizing filters
MidnightSun
Aug 31, 2009 15:22 |  #3
shutter_imadness wrote in post #8544459 (external link)
Dude, you're a lifesaver....I must've set that one when fooling around one day. Wow, what a relief!!...Thx a bunch....:D
Dave
shutter_imadness
Aug 31, 2009 20:29 |  #4
Glad to have helped :D
929 views & 0 likes for this thread
350 IR Issue
Latest registered member is SDJ
527 guests, 224 members online
