If I was to buy a 2nd hand camera from the US is there anything I need to convert so it all works here, like plugs for battery charger etc? If so where do I buy this stuff and how much does it cost?
Whippeticious Goldmember 2,302 posts Likes: 34 Joined Nov 2008 Location: Australia More info | Aug 29, 2009 22:55 | #1 If I was to buy a 2nd hand camera from the US is there anything I need to convert so it all works here, like plugs for battery charger etc? If so where do I buy this stuff and how much does it cost?
Replaces Goldmember 1,079 posts Joined Aug 2009 More info | Aug 29, 2009 22:57 | #2 I believe AUS uses 220V plugs... am i right?
Whippeticious THREAD STARTER Goldmember 2,302 posts Likes: 34 Joined Nov 2008 Location: Australia More info | Aug 29, 2009 23:02 | #3 240v
yogestee "my posts can be a little colourful" More info | Whippet,, all you need is a US to Australian power adapter for your charger.. You can buy one at any travel luggage store for around 20 bucks.. Jurgen
aero.nz Member 216 posts Likes: 8 Joined Feb 2008 Location: Melbourne, Australia More info | Aug 29, 2009 23:16 | #5 has anyone brought a body from say B&H or other US online retailer and taken it to canon Aus? what happened then.... I realise it wont be covered under warranty however would they service it etc? EOS RP| EF50mm F1.8 STM | Manfrotto 190Pro+804 head
Whippeticious THREAD STARTER Goldmember 2,302 posts Likes: 34 Joined Nov 2008 Location: Australia More info | Aug 29, 2009 23:20 | #6 Yep I'd like to know that too, basically I want to know if there's any disadvantages to buying from overseas.
Aug 29, 2009 23:28 | #7 The Canon OEM charger and most 3rd party chargers as well, will work anywhere in the world but you will need adapter prongs for appropriate electrical outlets.... My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
yogestee "my posts can be a little colourful" More info | Aug 29, 2009 23:34 | #8 kitacanon wrote in post #8547507 The Canon OEM charger and most 3rd party chargers as well, will work anywhere in the world but you will need adapter prongs for appropriate electrical outlets.... Exactly kitacanon.. I've taken my chargers to quite a few countries,,China and around SE Asia, including Australia.. Camera, mobile phone, Ipod chargers for example.. Jurgen
TheMoose Cream of the Crop 5,106 posts Likes: 1 Joined Jan 2009 More info | Aug 29, 2009 23:48 | #9 You won't even need adapters for the chargers (from a travel shop or similar). I had a 1D classic and it came with the charger but it was bought in the US so it had the wrong adapter. I used the plug from my 400D's charger because it was a standard figure 8 one.
SR071 Senior Member 276 posts Joined Jul 2005 Location: Melbourne Australia More info | Aug 30, 2009 00:15 | #10 Good point Moose - 99.9% of them are all figure 8 plugs, so you just need to note the input voltage, which is typically 110 to 230 or 240 - and you're all set. Matt *20D YAY! My first *real* digital camera. 5DIII 1Dx and 1Dx and 1DIV And all the heavy glass...Plus a flash or seven...
Whippeticious THREAD STARTER Goldmember 2,302 posts Likes: 34 Joined Nov 2008 Location: Australia More info | Aug 30, 2009 00:20 | #11 When you say a figure 8 is that the shape of the battery, cause I have a 400D and the battery is more like a little brick, with a flat bottom and a rounded top. I have seen other batteries that look like 2 tubes joined together.....sort of, guessing they're the figure 8s, not explaining myself very well sorry. I dont know why my battery is different but would the chargers be the same?
yogestee "my posts can be a little colourful" More info | Aug 30, 2009 00:29 | #12 Whippeticious wrote in post #8547672 When you say a figure 8 is that the shape of the battery, cause I have a 400D and the battery is more like a little brick, with a flat bottom and a rounded top. I have seen other batteries that look like 2 tubes joined together.....sort of, guessing they're the figure 8s, not explaining myself very well sorry. I dont know why my battery is different but would the chargers be the same? No mate.. It's the shape of the lead/plug that goes into your charger.. Jurgen
Whippeticious THREAD STARTER Goldmember 2,302 posts Likes: 34 Joined Nov 2008 Location: Australia More info | Aug 30, 2009 00:40 | #13 aaaaaahh Yes! it's the same! thanks
bubbazanetti Perhaps it was a result of anxiety. 857 posts Likes: 1 Joined Jan 2005 More info | Aug 30, 2009 01:59 | #14 Whippeticious wrote in post #8547729 aaaaaahh Yes! it's the same! thanks so hang on, I am not good with things electrical, are you telling me I dont need to buy anything to make it work here, I just use that figure 8 lead (that I already have) to plug into the battery charger that will come from the US? Whip im an aussie sparkie & AS60038 says the voltage for australia is now 230 +10% -6%. Has been for some time.
TheMoose Cream of the Crop 5,106 posts Likes: 1 Joined Jan 2009 More info | Aug 30, 2009 03:57 | #15 Whippeticious wrote in post #8547729 aaaaaahh Yes! it's the same! thanks so hang on, I am not good with things electrical, are you telling me I dont need to buy anything to make it work here, I just use that figure 8 lead (that I already have) to plug into the battery charger that will come from the US? That's exactly what I did. I used my 400D's charger cord.
| Latest registered member is semonsters 887 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
