Thread started 30 Aug 2009 (Sunday) 05:15
Creating Negatives from Prints?
nicshow
Aug 30, 2009 05:15 |  #1
Someone (for some reason) wants to re-create negatives from prints they have. Does anyone know of a reputable lab that might do this?
Nic
http://www.flickr.com/​photos/nicshow/ (external link)
http://www.nicshowalte​r.com (external link)
number ­ six
fully entitled to be jealous
Aug 30, 2009 14:13 |  #2
Pro labs used to make internegatives from slides for printing. Basically the same thing, but I can't suggest a lab...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
jra
Aug 30, 2009 18:02 |  #3
You could always take a picture of the print with a film camera....Other than that, I know of no labs that do it :)
yogestee
Aug 30, 2009 21:41 as a reply to  @ jra's post |  #4
One of the pro-labs I dealt with when I was shooting film used to offer this service and did it well..
I haven't heard of this service for years..
Jurgen
Bodog
Joined Feb 2004
Aug 30, 2009 22:08 as a reply to  @ yogestee's post |  #5
Any good photographer should be able to make a copy on film. But that's the best you're going to be able to get; a copy. AFAIK there's no going backwards from print to negative.
JimE
Color? It's all relative...
number ­ six
Aug 30, 2009 22:37 |  #6
Bodog wrote in post #8552470 (external link)
Why not? A negative has much higher resolution than a print, and any decent internegative would lose nothing from a print.
-js
"Be seeing you."
Wilt
Aug 30, 2009 22:51 |  #7
number six wrote in post #8552660 (external link)
-js
...contrast build up!
Bodog
Joined Feb 2004
Aug 30, 2009 23:00 |  #8
-js
Exactly...
JimE
yogestee
Aug 30, 2009 23:19 |  #9
-js
It's not as easy as it sounds.. Every time you make another generation you usually lose some quality.. One has to ensure the lighting is perfect,,flat and evenly lit.. Glare is a huge problem especially with glossy prints.. Getting the subject contrast to match the image contrast is very important too..As Wilt mentioned and increase in image contrast is a possibity.. Any faults in the print will be amplified when copying to negative..
The optics you use is also vital.. With most lenses there is resolution fall off from edge to edge, corner to corner.. They are not really designed to photograph two dimensional subjects.. There are specially designed lenses for photographing 2D subjetcs,,flat field lenses which are rare and expensive.. I found a prime macro best suited for copy work..
Coping works best if you shoot a fine grain B/W film.. I used to copy B/W using Ilford PanF 50 exposed at 40iso then pulled back during development.. But this doesn't help if you want to have a colour negative..
Jurgen
ralff
Aug 31, 2009 05:14 as a reply to  @ yogestee's post |  #10
Back in the 70's it was 3 bucks per interneg, for each print, on 120 film B&W. My sister wanted several hundred done, I bought a copy stand and did it for her, got a nice copy stand out of it and she saved a TON of money for all the pictures I copied. There are labs out there that will do it but it WILL cost you. Have you tried a google search? Called local film labs? Wolf camera used to offer the service. One question though, why do they want a negative? Prints can be scanned then printed from the scan.
Canon 6D - Canon 7D - gripped, Canon 50D - gripped, EFS10-22mm, 17-40 f4 L, nifty-fifty, EF 28-135mm IS, 100-400 f4.5-5.6 L IS USM, Tokina AT-X 100mm f/2.8 ProD Macro, Benbo Trekker, Feisol 3371 w/ Kirk BH-3 ball head - Epson Pic-Mate, Epson 2200, Epson 3880 :D http://www.flickr.com/​photos/WNC_Ralph (external link)
rral22
Aug 31, 2009 08:45 |  #11
yogestee is right. There is not much point in trying to make a negative from a print. The print has already lost much of the original resolution, and there is no way to get it back with another reproductive process.
You can't get more resolution than the original object contains. A picture of a TV screen isn't going to reveal more resolution than the screen can produce. Same with prints.
number ­ six
Aug 31, 2009 13:13 |  #12
Good point about the contrast. Hadn't thought about that.
As far as resolution, though, I think I have been misunderstood: the print is the limiting factor, not the negative.
But this is all "could you do it" stuff - why does this person want to get negs from prints, Nic?
-js
"Be seeing you."
nicshow
Aug 31, 2009 16:19 as a reply to  @ number six's post |  #13
I wish I knew and understood better. Unfortunately, I'm getting the inquiry 2nd hand so I just do not know.
1,514 views & 0 likes for this thread, 8 members have posted to it.
1036 guests, 107 members online
