Thread started 04 Sep 2009 (Friday) 05:39
Another Sharpening Question
Jonathan
Sep 04, 2009 05:39 |  #1
I have created an action in PS that changes the image mode from 16bit to 8 bit and reduces the image size by 50%. I use this at the end of my workflow before I finally save as a jpeg to upload to the web. Should I apply sharpening bofre I resize (which is what I do at the moment) or after I have resized?
Any advice appreciated.
"Don't believe everything you read on the Internet" - Winston Churchill
My blog siteexternal link
My Gear List
My Flickrexternal link
Hannya
Sep 04, 2009 05:44 |  #2
Hi. I always sharpen as the last step. So I would sharpen after I'd reduced the size. That way you can adjust the sharpening to suit the needs, e.g. for web or print.
Hope that helps.
“Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson
Sports Pics (external link)
philmar
Gallery: 123 photos
Sep 04, 2009 10:33 |  #3
Sharpen AFTER you downsize. Adobe's downsizing algorithms are not the best. That's why you need to sharpen after downsizing.
A photo I took HERE published in National GeographicTime on your hands? Then HERE'S plenty more photos to nibble on (external link):
http://https …photos/phil_mar​ion/albums (external link)
or follow me: https://www.instagram.​com/instaphilmarion/ (external link)
AlphaChicken
Knot Hank
Sep 04, 2009 11:25 |  #4
philmar wrote in post #8583037 (external link)
Who's downsizing algos ARE the best?
I am Henry. NOT Hank. And certainly not a length of rope tied in a knot. ;)
My family calls me Hen, but you can call me Chicken. See you out there!
|Deviant Art (external link)
|Facebook (external link)|Gear List
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Sep 05, 2009 08:55 |  #5
Regardless of the downsizing method used, you will want to sharpen after downsizing. It doesn't matter which program is used. The last step should always be sharpening for output.
AlphaChicken wrote in post #8583353 (external link)
For downsizing for web images I would not worry about this at all. Most any program, used correctly, will produce a very fine downsized image.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
PhotosGuy
Joined Feb 2004
Sep 05, 2009 10:37 |  #6
For some images where you've screwed up & don't have the sharpness you wanted, you might sharpen a bit before resizing, too.
Sticky: Sharpening Tips & Tricks, Tutorials, and FAQ
And keep in mind that there's no "rule" that everything in the image has to be sharpened the same amount?
A few words on SHARPENING:
Pete
Sep 05, 2009 10:42 |  #7
To my mind, the only sharpening that should be applied using an action should be capture sharpening (which will use the same settings for every photo taken with a particular body).
Any creative/output sharpening should really be applied manually. I tend to use output sharpening only if I'm going to be printing.
Pete
UK SE Catch of the Day
1,398 views & 0 likes for this thread
Latest registered member is kenf
802 guests, 301 members online
