Thread started 04 Sep 2009 (Friday) 09:38
1D Mark IIN: Too heavy for soccer?
Ralpho
Sep 04, 2009 09:38 |  #1
I shot a soccer game Wednesday with my new (used) Mark IIN and found it tiring to hold camera up with right hand while working zoom lens with left hand. Problem is compounded by need to keep thumb on * button and forefinger on shutter button.
Is there a wrist strap that will take some of strain off my right arm and hand?
Or should I put camera on a monopod?
How do other Mark II shooters handle this situation?
CAL ­ Imagery
Sep 04, 2009 09:41 |  #2
What lens did you use?
A monopod would probably help. Also, using your left hand/arm to hold the lens to alleviate the weight of the camera and lens.
Christian
Cl!ckFoto
Sep 04, 2009 09:43 |  #3
I handheld a 1DmkII with a 300f4 mounted to it all day on the golf course. Get a monopod if its too heavy.
-Matt
FOR SALE!
5D|17-40L SOLD!|85f1.8|Sigmalux SOLD!|580ex SOLD!
Ralpho
Sep 04, 2009 09:48 |  #4
nphsbuckeye wrote in post #8582682 (external link)
I used my trusty 100-300mm Canon lens. Sorry I didn't mention it in original post.
Problem with monopod is that it becomes difficult to react to a fast-paced game, particularly if one wants to re-orient camera for a vertical shot when players get too close for horizontal.
CAL ­ Imagery
Sep 04, 2009 09:53 |  #5
Have your arms and elbows against your body so they can use the body as support, instead of your elbows pointed outward. You probably don't need to hold your camera up the whole time. You could always no tighten the tripod ring to quickly change orientation. Pump iron..
Christian
Mr. ­ Clean
Sep 04, 2009 10:02 |  #6
I would agree that some weight training is certainly going to help. The Mark II + 100-300 is not terribly heavy and shouldn't be.
That said, rest as often as possible and keep your elbows in which will utilize more of your body versus just your arms.
But seriously, start some strength training and DON'T FORGET YOUR CORE!
Mike
some shots @ Zenfolio (external link)
LMP
Sep 04, 2009 10:41 |  #7
Ralpho wrote in post #8582727 (external link)
It's all a matter of practice, monopod for 300-400mm 2.8 len's and 70-200 handheld.... seemples ;)
Headshotzx
Sep 04, 2009 10:51 |  #8
If I had a long day in school and needed to shoot sports after that in the late afternoons, I'd definitely mount my setup (70-200 2.8L IS + camera) on a monopod with a tilt head. I just don't like holding the entire setup when I'm tired.
If I am fresh and had a good night's sleep before that, though, the 70-200's no problem.
I would say that you probably should make sure your handholding technique is proper first. If you know it's proper, then by all means get a monopod and a 234RC tilt head to aid you.
Cheers,
Zexun
Zexun | Flickr (external link) | YouTube (external link) |
zincozinco
-Followers of Fidget-
Sep 04, 2009 10:55 |  #9
Cl!ckFoto wrote in post #8582700 (external link)
monopod is the way to go!
Living the life, overexposing...
Web (external link), Blog (external link) Name: Mike, Maik, Micke or just zinco.
LMP
Sep 04, 2009 11:25 |  #10
Headshotzx wrote in post #8583156 (external link)
Cheers,
Zexun
Isn't the lens collar mount sufficient to attach the monopod to ? Why a tilt head ?
H20boy
Sep 04, 2009 11:35 |  #11
I use a monopod and the tripod collar to go vertical when necessary. I don't use a tilt head in the equation unless i'm going up and down repetitively. At a soccer game, I get on one knee, use the monopod and click away.
Matt l My Galleries (external link)
5d2 l 1d3 l 24-70/2.8 l Σ 50/1.4 l 70-200/2.8 IS l Σ 120-300/2.8 l 135/2 l 15/2.8 FE l Tam 90mac
tracknut
Joined Jun 2005
Sep 04, 2009 12:09 |  #12
And yes, a wrist strap will help a lot in terms of relieving strain on your fingertips if you're not using a monopod. I have a couple of the Camdapter (external link)straps and love them.
Dave
Performance/sport dog photographer (external link)
Facebook (external link)
"Always available to shoot your dog"
Headshotzx
Sep 04, 2009 12:47 |  #13
LMP wrote in post #8583356 (external link)
Because 100-300mm allows him to zoom out when the players come close and that usually means tilting down a little. He's having problems handholding his setup, and if he only gets a monopod without a tilt head, he might solve the weight / unsteadiness issue but end up having back strain especially when the players are near to where he's shooting all the time.
JBF
Sep 04, 2009 14:09 |  #14
Don't use the * button on the back. Just pump the shutter button.
JBF
Canon 7D, Canon 1D Mark IV, Canon 24-105L f/4, Canon 35L 1.4, Canon 200L f/2.8, Canon 70-200L II IS f/2.8, Canon 300L f/2.8IS, 580ex Flash, 430ex Flash, 1.4X Converter. Bunch of other crap! I want the new 500mmL and the 200L f/2.0
FlyingPhotog
Cream of the "Prop"
Sep 04, 2009 14:14 |  #15
You don't have to keep the monopod firmly on the ground the whole time.
When I'm out stalking aircraft I use a monopod with a 300mm f/2.8 and I'll just pick the entire thing off the ground to tilt up and shoot (and yes, I have a ballhead on mine too.)
The thing with the monopod is it takes the weight entirely off between shots. If I can get the shot while the 'pod is touching the ground, great. If not? No biggie...
Jay
3,524 views & 0 likes for this thread, 18 members have posted to it.
1205 guests, 129 members online
