Looking for C&C on composition and processing. Thanks for any help you might have to offer.
Walkingmanblues Member 200 posts Likes: 19 Joined Jun 2008 More info | Sep 08, 2009 14:24 | #1 Looking for C&C on composition and processing. Thanks for any help you might have to offer.
believer_01 Member 52 posts Joined Jul 2009 More info | Sep 08, 2009 14:33 | #2 Great location. I would clone out the poles. Did you manually select the white balance. The sky in the center of the photo is a little darker and that occurs sometimes when the camera is set on auto WB. Nice shot.
Sep 08, 2009 17:04 | #3 believer_01 wrote in post #8606433 Great location. I would clone out the poles. Did you manually select the white balance. The sky in the center of the photo is a little darker and that occurs sometimes when the camera is set on auto WB. Nice shot. I can't remember, but I shot them in RAW and synced the settings in Lightroom. Could a CPL filter create that effect?
lindsaytblum Goldmember 2,540 posts Joined May 2008 Location: Chesterfield, MO More info | Sep 08, 2009 17:12 | #4 Gorgeous capture! I agree about cloning out the poles. Canon 7D | 24-70mm f/2.8L II, 135mm f/2.0L, 100mm f/2.8L IS USM, 85mm f/1.8
Sep 08, 2009 17:29 | #5 lindsaytblum wrote in post #8607364 Gorgeous capture! About the sky discoloration, CPL's (especially slim ones) have been known to cause that effect The review goes on to say, "Using the B+W 77mm MRC Slim Circular Polarizer Filter at an ultra-wide focal length (where thin filters are most necessary) can result in an unevenness in your photo. Wide angle unevenness is especially noticeable in blue skies - the sky will be the darkest at a 90 degree angle from the direction of the sun light." That seems a likely culprit, then, thanks. I shot using a 17-40mm at the 17mm mark AND I was using a slim B+W CPL. I've noticed the effect in other photos which is why I thought that might be it. Funny, though, I've come to like the effect a little bit. Thanks for the post!
| Latest registered member is ANebinger 932 guests, 147 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
