Can they be used at the same time? I'm using the 17-40 and don't want any vignetting. I've been looking at Lee's holder but can it be used with let's say a B+W screw in ND filter?
Oliviero Senior Member 409 posts Joined Jan 2009 More info | Sep 09, 2009 09:49 | #1 Can they be used at the same time? I'm using the 17-40 and don't want any vignetting. I've been looking at Lee's holder but can it be used with let's say a B+W screw in ND filter?
edrader "I am not the final word" More info | Sep 09, 2009 09:59 | #2 Oliviero wrote in post #8611524 Can they be used at the same time? I'm using the 17-40 and don't want any vignetting. I've been looking at Lee's holder but can it be used with let's say a B+W screw in ND filter? and your camera is...............? http://instagram.com/edraderphotography/
Sep 09, 2009 10:45 | #3 Ah, sorry, I have the 5D2... I knew there was something I'd forget
Sep 09, 2009 11:52 | #4 I just found some photos on Flickr which have been taken with this exact setup so apparently it is doable. Some vignetting is visible at 16mm though but nothing that can't be corrected.
Sep 12, 2009 15:02 | #5 Doesn't anyone have any info regarding this? Again, is it possible to mount place a Lee filter holder on top of a B+W 110 filter?
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | If your ND filter has front threads, sure, you can attach the adapter ring to that and then attach the holder. However, it could be tricky if you need to pre-focus and then attach the ND filter. Depending on the available light, threading on a 10-stop ND and then adding the holder afterwards could be a PITA, especially if you accidentally change the focus after all of that. Vignetting can also be an issue, depending on your crop factor and focal length. But to answer your question, yes. "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
Sep 12, 2009 16:48 | #7 Thanks argyle. I have a 17-40 on FF so I suppose I might end up with some vignetting. Sure sounds like a PITA though.
NYPhotog Member 228 posts Joined May 2009 Location: New York, NY More info | Sep 13, 2009 01:58 | #8 Oliviero wrote in post #8632630 Thanks argyle. I have a 17-40 on FF so I suppose I might end up with some vignetting. Sure sounds like a PITA though. I hope the B+W 110 filter has front threads.. Yes, it will be a PITA and there will be serious vignetting.
I think the B+W 110 filter has front threads which is good. However, I'm still worried about the vignetting. Has anyone tried the Lee push-on holder?
| Latest registered member is Niagara Wedding Photographer 1323 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
