Anyone here willing to let me ship my a630 to them to do this for a fee? I could probably do it myself but I'd rather not screw it up and end up with a paperweight. I would pay shipping both ways and include a little cash for your troubles.
joestacey06 Member 123 posts Joined Mar 2009 Location: Central Pennsylvania More info | Sep 10, 2009 22:31 | #1 Anyone here willing to let me ship my a630 to them to do this for a fee? I could probably do it myself but I'd rather not screw it up and end up with a paperweight. I would pay shipping both ways and include a little cash for your troubles. Canon SX40 HS
MasterFX Member 129 posts Joined Dec 2008 More info | Sep 11, 2009 03:51 | #2 ??? You don't have to screw it up. Just download the CHDK for the A630 (http://mighty-hoernsche.de/ Canon 450D/XSi, Tamron 10-24mm f/3.5-4.5, Canon EF-S 18-55mm IS f/3,5-5,6, Tamron 28-75mm f/2.8 XR Di LF, Canon EF-S 55-250 IS, Canon EF 50mm f/1.8 II, Canon EF 85mm f/1.8 USM, Nissin Speedlight Di622
hnikesch Goldmember More info | Sep 11, 2009 15:29 | #3 It's easy if you have a problem just post here and we will help you Hans
Woolburr Rest in peace old friend. 66,487 posts Gallery: 115 photos Best ofs: 2 Likes: 143 Joined Sep 2005 Location: The Tupperware capitol of eastern Oregon...Leicester, NC! More info | Sep 11, 2009 16:00 | #4 CHDK isn't permanent....simply follow the directions on the site. Lots of people can answer specific questions you might have. People that know me call me Dan
gerrydee Member 104 posts Joined Apr 2007 Location: Southwestern Ontario More info | CHDK is only a small program, software, and does not affect the hardware of your camera. Even if you did screw up, you would only have to delete the files from the memory card and you are back to scratch. Canon Powershot SX10 IS
Sep 11, 2009 23:38 | #6 OK, I'll do it. First question, does it HAVE to be a 4gb or smaller card? If so I'll have to get another card. Mine is an 8gb. Canon SX40 HS
hnikesch Goldmember More info | Sep 12, 2009 09:02 | #7 If you want to have CHDK auto load on camera power up yes you will need a 4gb card or smaller. but you can manually start CHDK on a 8gb card and only start it when you want it. I auto load using a 4gb card. manual start is not that bad, you just go to the canon menu in play back mode and select firmware update, then it runs until you power down, you know after writing this it is a pain to manually start Hans
psinkant Senior Member 419 posts Joined Jun 2008 Location: Northern Virginia More info | Sep 13, 2009 02:32 | #8 I just did the CHDK on my SD1000. It worked like a charm. I tried to do it with an 8gb SD card but it didn't work. However, when I tried it with a 2gb card, it worked. It only took me 30 minutes from start to finish. If u know what ur doing, I'm sure it could take less time. Good luck! -FF and crop bodies w/ some lenses and S90-
EloquentPixels Member 63 posts Joined Feb 2007 Location: Vancouver, B.C. More info | You need to set up multiple partitions on cards larger than 4gb. A small one (32mb) that's FAT16 and the rest going to a large FAT32 partition. Problem with this method is that you always have to boot with CHDK on, otherwise the camera ends up using the small partition. www.eloquentpixels.com
| Latest registered member is Marcsaa 502 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
