Thread started 11 Sep 2009 (Friday) 13:52
Softlighter II or PCB PLM System?
DD974
Sep 11, 2009 13:52 |  #1
Do these produce the same results? If anyone has experience with these please chime in.
Softlighter II (external link) or Paul C. Buff PLM System (external link)?
DC~
OneStrobe
Joined Sep 2009
Sep 11, 2009 18:10 |  #2
The softlighter is supposed the act as a 3 in 1 tool. It's a shoot through, reflective, and brolly-box all in one. The softlighter is also known to eat up a lot of light so be weary of that if you're just using a single strobe.
The PLM has a different technology to it. It's body is specifically designed to shoot the light back straight out of the reflective surface. What this means is that you'll get a more directional light and less spread overall, as well as a little more efficiency from your lights since most of the light is being directly reflected instead of spread around a larger area like a normal reflector.
There is an optional diffuser for the PLM which will turn it into a brolly-box for more diffused/softbox look. The only thing I'm unsure of is if the PLM is specifically designed for monolight placement or if it will work with strobes as well.
2,042 views & 0 likes for this thread, 2 members have posted to it.
1445 guests, 136 members online
