Thread started 13 Sep 2009 (Sunday) 07:59
Expodisc Techniques & Tips - White Balance
Roxie2401
Sep 13, 2009 07:59 |  #1
Hi - I just received an Expodisc and would like to hear about experiences using this device for White Balance.
For example, I want to photograph school band concerts, stage plays where I would like the colors to be as accurate as possible, etc. In most locations, the stage front lighting is coming from ceiling recesses so I can't aim the Expodisc toward the light. Any suggestions? In this case, I could probably shoot several shots with different Kelvin settings and try to "find" the best. So, did I waste the money on the Expodisc? Is it a good tool to have "in the bag?"
That was a specific, but I would really like to hear about other applications and techniques. While good, Auto White Balance is a compromise at best.
If this was not posted in the correct Forum, a suggestion on where I would get the most responses would also be appreciated.
I should mention, "why the Expodisc" and explain that I would prefer not to do post-processing to correct the White Balance - I know it can be done, but taking the shots is more fun that working in the digital darkroom.
Thanks very much.
SkipD
Joined Dec 2002
Sep 13, 2009 11:19 |  #2
If you cannot aim the camera with the Expodisc mounted at the light source(s) that is/are illuminating the subject, then the Expodisc (or any of its clones) is a totally useless item.
Even when you can aim the camera at the light source, you have to go through the "custom white balance" procedure to use it.
I find using a neutral gray card (such as the WhiBal and others) much simpler. While I can use it to do a "custom white balance", I merely place the card in the scene - or at least in the same lighting as the scene - for a test shot. Since I always shoot in RAW mode, it is a simple thing to sample the gray card in the test shot and transfer the resulting color temperature and tint values to the rest of the shots during a batch conversion.
Skip Douglas
590 views & 0 likes for this thread
Latest registered member is Guashumerda
829 guests, 186 members online
